F1_eng wrote:Volumetric efficiency is the measure of an engine's efficiency with regards to filling it with air, that's what it has to do with engine efficiency. It allows you to compare the efficiency of engines of different sizes at filling the cylinder.
Engine efficiency is thermal efficiency. I assume you know that volumetric efficiency serves to compare engines as air pumps, not to compare them in regards to produce work.
Surely they are related somehow, but the things that give an engine its characteristica engine efficiency is the kind of thermal cycle. It's like saying that all tall men are fat men: sure they are related, but other factors influence more if you are fat or not besides your physical stature. And, pleeze, you DON'T need to explain to me what VE is, either. I repeat: I have no idea why you mention it, I'm not saying I don't understand what it is.
However, now that is a Sunday, could you ellaborate about two things? Why are you mentioning VE in a discussion regarding diesel vs gasoline? In which way VE is related to a thread about diesels in F1? As I said, the valve size and manifold pressure is what influences VE the most, period.
Sure your posts are getting shorter, I still haven't comprehended very well (with all respect) what your point is. Aren't diesel engines leaner on fuel? Detonations aren't faster than sound? Aren't Diesel engines more reluctant to detonate? Aren't Diesel engines low revving and easy on bearings? Aren't Diesel engines used when endurance is needed because of its high torque/low rev combination? Isn't Diesel oxygen density double or triple the one of a gas engine before combustion? Doesn't that mean that a slow burning fuel, like oil, can be burn in a much more efficient way than in an Otto engine and thus doesn't it make them have a thermal efficiency better than gasoline ones? Aren't fuel throttled engines leaner than air throttled ones?
No babbling about VE will make those points untrue and emminently related to this tread.
I can say that I'm still surprised by the tone of your posts. We're used here to correct each others posts (if that is the case) without having to call ourselves morons or qualifying the quality of knowledge of every one.
The aim of the thread is the use of Diesel in F1, I think, so, please, if you find so displeasing and limited my posts on the subject, by all means, dazzle us with your illimited knowledge about the point at hand, instead of saying that something is wrong but not explaining why
I complain about you entwining the conversation by putting in my mouth things I didn't say and then rebating those non-existent points of view. I learned about the point at hand in the same way you did: in college. Assuming that I learned them in Wikipedia is insulting, to say the least. I may be more stupid than you are, if that's what you mean, but I haven't studied less than you.
If I had a moderator I could complain about that, I would. Unfortunately, I'm the mod here, so I have no one, except you, to complain about your lack of education. I'd love to hear your answer about that point, now that is a Sunday...
