Fascinating stuff as usual 747! According to this article, they did that to help compete with the AWD Opel and Alfa entrants:747heavy wrote:brings back memories of the TMD![]()
Mercedes (AMG) used movable ballast (via hydraulics app. +/- 400 mm) in there DTM/ITC cars in the mid 90´s to compete with there RWD car against the AWD Alfa&Opel.
The ballast was moved active during accel&braking and between low&high speed corners
to change the weight distribution (balance) front to rear during the duration of a lap, using long/lat accel and speed data to define the position of the car on the track.
Fantastic! I can totally imagine what this would look like now that you mention it. That would be so great to see, pullrod setup that maintains the raised nose. I wonder how restrictive the rules are on the tea tray size and shape, though. Can it be brought forward far enough to accomplish this?marcush. wrote:I think we will see spectacular front suspension layout in 2011 by RedBull.
We will see Pullrod activation the damper elements will be situated on top of the Tea tray.
This will serve a double function:
It will move heavy components to a lower part of the car ,reducing cofG height and as a added feature Newey will be able to bend the tray area legally upwards under maximum load conditions so we will see the RBR7 running even lower than the RBR6..Am I serious ? who knows....
I seem to remember Newey was talking about new areas of development for next year on the mechanical side...and he will again be stealing a march...maybe not even pullrod ?
maybe it will not quite be as radical but I expect a different front suspension from RedBull as well as a even more pronounced use of bendy components
Or just make sure the ballast can return to a defined area that appears fixed for inspection, and a has a bomb-bay door you need tools to open. What's that? Spirit of the Rules, you say? Well, I'd say the regs in general lost their soul some time ago...Belatti wrote:thats a nice idea that wont even require the fluid, just a couple of strings would do the jobFormula None wrote:How about: tungsten spheres or cylinders lined up in fluid filled tubes routed through the chassis, change the pressure on either side of the chain to make them travel along the length of the tube. You could have ballast piped anywhere you want. Or are the tungsten blocks they used spec'd already?![]()
Well, you could securely fix the filled cylinder to the chasis and require tools to remove itgodlameroso wrote:In the regulations it states that ballast must be securely fixed, and requires tools to remove or put in.
A solid tin block (a little lighter than lead, so diminishing returns here...) could be installed as usual. But you install it in an oven and pump that molten tin around. Or just use it as the primary heat extraction from the engine and run the engine a little hot747heavy wrote:Another (more esoteric) option would be to mind about the use of mercury for such an application - just kidding
I do believe that the X wings appeared on a tyrrell first ... I also believe that tyrrell was the first modern raised nose design (or anhedral wing, as I heard it called at the time).Giblet wrote:Mclaren has quite a history of coming up with innovations that nobody else was even hovering near, so counting them out would be silly.
Inerter, dual brake pedals, zero keel suspension, f-duct, carbon fiber monocoque, x-wing, etc. They have always been innovators, rarely ever slow, and rarely ever copiers for their core design.
Tyrell also had a single beam front wing support, but I'm not sure if they were the first with that or not. I'd like to see someone (except Virgin who couldn't keep the wing on with two) attempt this in 2011.gridwalker wrote:I do believe that the X wings appeared on a tyrrell first ... I also believe that tyrrell was the first modern raised nose design (or anhedral wing, as I heard it called at the time).
Good old Ken Tyrrell ... a highly under rated innovator
EDIT : originally quoted wrong post!
EDIT 2 : Seeing as you were talking about movable ballast, that was another tyrrell trick
Correct: The front wing MUST be supported by two elements. Its in the rules.I am not certain whether the regulations governing the standardised FW central section would allow this
Tyrrell had the first higher nose cone on the 019 in 1990:Formula None wrote:Tyrell also had a single beam front wing support, but I'm not sure if they were the first with that or not. I'd like to see someone (except Virgin who couldn't keep the wing on with two) attempt this in 2011.gridwalker wrote:I do believe that the X wings appeared on a tyrrell first ... I also believe that tyrrell was the first modern raised nose design (or anhedral wing, as I heard it called at the time).
Thank you I stand corrected.gridwalker wrote: I do believe that the X wings appeared on a tyrrell first...
