correction, the rb6 is straight, but the fw32 has a curved profile:
Doesnt seem big deal to me. Thats what happen at high speed anyway.xpensive wrote: Imagine duct openings being 0.1 square meter, air-speed of 90 m/s (324 km/h) and a total Cv through the passage of 0.5,
gentlemen, that's 22 kW or 30 Hp!
Oboy, silly me, but that settles every dicussion I guess?Belatti wrote: ...
Where do come to this numbers? Could you paste here source? Please i will be glad! Thx! Or are this just your predictions?Pedro wrote:The water system is typically dispersing around 110 kW and engine oil 100 kW. KERS needs around 4 kW (for battery pack and motor), hydraulic system 4 kW and 12 kW for transmission.
If an engine convert 30% of the heat to work, about 40% of the heat will go out with the exhaust. The last 30% will be shared by coolant, oil and surrounding air.WhiteBlue wrote:The most basic figure for the total cooling requirement would be the efficiency of the engine. For current engines it is believed to be around 29%. So 71% of the max fuel flow times specific energy of the fuel has to be dumped in heat. More than 250 kW of that energy will go out with the exhaust gas. What is left will be dissipated via the water, the oil and the surfaces of the drive train. If you compare the size of the coolers for water and oil it would be a logical assumption that the water will carry 80% of that or more.
