[/quote]
someone accused the carbon tube in this picture as acting as the ARB in this setup. obviously, a carbon fiber tube this diameter would have a high enough resistance to torsion to not allow any usable roll movement. It took a few minutes trying to figure out what the heck the transverse silver Ohlins damper was doing to realize that in roll, the whole rocker tube assembly moves laterally, so there must be a spring or two inside the pivot housings on each side to control roll stiffness.
Back to the subject matter though:
how have they interconnected the front and rear in F1? is it hydraulic like the rally car systems that are now banned, or have they combined the front and rear linkages in a similar way to the way a 3 spring or monospring setup does the left and right?
I think ya'll are missing something on the point of moving the roll stiffness from corner springs to the ARB. When a corner spring is resisting roll, it only places a force on it's corner, where as the ARB is applying an equal force on each side, in opposite directions. I am just going back to basic tuning principals. whenever you increase the diameter of an ARB to reduce body roll, the tire on the inside of the turn is lifted more, reducing traction at that corner, where as if you instead increase the spring rates to reduce body roll, less weight is transferred to the outside tire.
