could do couldn't itJimClarkFan wrote:This has made the championship interesting again...
i see what you meant by it, sorry i thought you meant something elseCylinder wrote:
The man is utterly relentless, you should know this. All he thinks about is "what is the gap to vettel", "How many points I need tommorrow give myself a realistic chance" His brain is one big championship calculator. No surprise whatsoever he is waiting around to find out what will happen.
Right in the back of the "cucumber". P24.F1 Fanatic @f1fanatic_co_uk
Stewards say Vettel's car "had 850 ml fuel on board which is not enough for the required one litre fuel sample."
stefan_ wrote:Right in the back of the "cucumber". P24.F1 Fanatic @f1fanatic_co_uk
FakeAlonso wrote:FIA decision: Vettel P24 and start from pitlane
stefan_ wrote:Right in the back of the cucumber.F1 Fanatic @f1fanatic_co_uk
As soon as I seen it I thought it was fuel, everything pointed to that.Cylinder wrote:stefan_ wrote:Right in the back of the cucumber.F1 Fanatic @f1fanatic_co_uk
Stewards say Vettel's car "had 850 ml fuel on board which is not enough for the required one litre fuel sample."![]()
A few of us said right at the beginning of this issue.
Forget all the bulllshit about mechanical failures, check the damn fuel levels before anything else is said or done.
f1talks.pl @f1talks
Sebastian Vettel excluded from qualification results.
Didn't work out this time, eh Mr. Horner...Ted Kravitz @tedkravitz
Vettel excluded can start from back of grid
