Alpine A522
BassVirolla
Re: Alpine A522
diffuser wrote:
15 Mar 2022, 01:16
You machine carbon fibre?
It's not unusual to make holes, cuts or slits in composite parts. Additionally, you usually trim the edges after demoulding.
I don't know in F1, but in industry and in boats manufacturing its, in fact, quite usual.
Re: Alpine A522
BassVirolla wrote:
15 Mar 2022, 08:43
diffuser wrote:
15 Mar 2022, 01:16
Here's the thing though, you're not gonna get much hotter that high 30s C in Bahrain and AR3 said they ran with them closed the whole time.
Re: Alpine A522
diffuser wrote:
15 Mar 2022, 11:09
BassVirolla wrote:
15 Mar 2022, 08:43
diffuser wrote:
15 Mar 2022, 01:16
I don't know they were closed the entire time, but they appear to have a configuration where they were closed.
Re: Alpine A522
16 Mar 2022, 01:37
diffuser wrote:
15 Mar 2022, 11:09
BassVirolla wrote:
15 Mar 2022, 08:43
Well, they obviously didn't need it. So why would they have double the cooling than they need?
Hopefully it has to do with a major sidepod change.
peewon
Re: Alpine A522
diffuser wrote:
16 Mar 2022, 03:21
16 Mar 2022, 01:37
diffuser wrote:
15 Mar 2022, 11:09
My very amateurish impression of A522 has been that Alpine has hedged its bets on design concepts (side pods, cooling systems, etc) and tried to leave themselves with opportunity to pivot once more definitive optimal solutions emerge with time. Perhaps influenced by their lack of flexibility towards the latter years of previous regulations to make drastic changes.
Stu
Re: Alpine A522
diffuser wrote:
12 Mar 2022, 15:33
https://cdn-1.motorsport.com/images/mgl ... a52-1.webp
https://cdn-1.motorsport.com/images/mgl ... 522-1.webp
From this angle, it looks like the air that comes down off the lower part of the sidepod get's sucked in under the floor through the slot cut in the floor.
I am thinking that could be a ‘cure’ for porpoising; a second, shorter Venturi. Airflow changes with speed (and so, therefore, does underbody pressure). You could really play with the aero balance if you had a second throat section.
Spoutnik
Spoutnik
Re: Alpine A522
peewon wrote:
16 Mar 2022, 03:59
diffuser wrote:
16 Mar 2022, 03:21
16 Mar 2022, 01:37
I agree with your impression because I've got the same. I would add they focused a lot on the Power Unit imo because of the "engine freeze" taking place... Furthermore, they now too well their main strenght compared to their last year's competitors (Alpha Tauri, AM, or even McLaren) is the fact the are a factory team rather than a customer one.
They could be fast on mid-high speed tracks even if the chassis isn't working really well like Ferrari 2019 or Williams 2014-16.
Re: Alpine A522
Stu wrote:
16 Mar 2022, 09:04
diffuser wrote:
12 Mar 2022, 15:33
I agree with your assessment but also think they are using that air off the sidepod. Like this pic...
Shows how the BINANCE guides the air right to the dip in the floor right by the openning.
Bombera
Bombera
Re: Alpine A522
Alpine engine
Jambier
Re: Alpine A522
Spoutnik wrote:
16 Mar 2022, 12:07
peewon wrote:
16 Mar 2022, 03:59
diffuser wrote:
16 Mar 2022, 03:21
Yes Rossi confirmed it to Canal+ F1 diffuser in France.
They will continue on their way, but they want to be able to jump to another solution if proven better.
Then if this is a big change, it will of course wait for next year. But having a first solid base, consistant while still being fast is a good option for them.
For 2023 I expect a huge convergence in terms for F1 shapes from all the teams
AeroDynamic
349
Re: Alpine A522
new side pod has a square-shape-bulk (Ferrari esque) now at the rear!
Bahrain Test:
Re: Alpine A522
For Blackout
JPBD1990
JPBD1990
51
Re: Alpine A522
Very Ferrari-esque slab-sided sidepods now. It also looks as though the possibly dip more towards the centre as opposed to across the entire surface as at the test. Interested to see more pics!
Re: Alpine A522
AeroDynamic wrote:
17 Mar 2022, 14:27
Hope you don't mind, put in what I think is a better comparison image....
Bahrain Test:
Re: Alpine A522
A cross between the Red Bull, sloping, directed at the tire squirt area, concept (which Alpine had from day one rather than copied to be fair), and the Ferrari shoulders.
