Ferrari SF-26
Ufi
Ufi
Re: Ferrari SF-26
Changes to the car
from @FulvioVigilante on X
#Ferrari has modified the terminal part of the narrower engine hood and opened two more vents, and it's also clear how the profile on the gearbox placed after the exhaust is truly structural.
https://x.com/FulvioVigilante/status/20 ... 69/photo/1
wowgr8
wowgr8
29
Re: Ferrari SF-26
I am impressed by the size of the cooling outlets compared to the competition. The Ferrari PU typically required a lot more cooling in the last engine reg cycle. If this trend holds then they've made a huge jump in ICE efficiency. Thank you to AR3-GP for the image
Re: Ferrari SF-26
Re: Ferrari SF-26
Gridlock
42
Re: Ferrari SF-26
.poz wrote:
18 Feb 2026, 10:23
ryaan2904 wrote:
18 Feb 2026, 10:01
Can this be copied by others before Race 1?
No.
"Engineers are permitted to position an aerodynamic device in that area of the car, provided it does not exceed a distance of 60 millimeters from the half-shaft (or driveshaft). Typically, this constraint prevents the device from extending beyond the tip of the exhaust; however, the Maranello engineers managed to bypass this hurdle by shifting the differential to the furthest possible rearward position
Is the Haas gearbox the same, ie could they run this?
#58
Courage
Courage
Re: Ferrari SF-26
Watching the broadcast, that wing looks incredibly close to the exit. Would it be possible the intent is something involving backpressure with the turbo exhaust? It almost looks inefficient from a downforce perspective. Wonder if this is anything to do with Ferrari's approach to their turbo management
Gridlock
42
Re: Ferrari SF-26
Real PJ's Beard
Re: Ferrari SF-26
Gridlock wrote:
18 Feb 2026, 14:14
.poz wrote:
18 Feb 2026, 10:23
ryaan2904 wrote:
18 Feb 2026, 10:01
No.
It comes down to positioning rather than gearbox shape. The Ferrari differential is pushed back to allow this device, and that is something that would require such an amount of re-engineering that teams would be altering their aerodynamic concepts.
In a costcap world, it now becomes a big question of whether or not it's worth investing those resources for what could be minimal gains
Dear God let this be the year
Santozini
Santozini
Re: Ferrari SF-26
Real PJ's Beard wrote:
18 Feb 2026, 14:33
Gridlock wrote:
18 Feb 2026, 14:14
.poz wrote:
18 Feb 2026, 10:23
No.
I have read in other places that its legality is being questioned. What is the general consensus here? I trust this forum more than most places
mzso
mzso
75
Re: Ferrari SF-26
18 Feb 2026, 09:47
18 Feb 2026, 09:44
:shock:
Blown rear wing. Exhaust will just shoot straight up.
Yea it's a blown diffuser, no?
https://i.ibb.co/2fBD17n/20260218-074518.jpg
What is?
All these imgbb images only show up this way:
Real PJ's Beard
Re: Ferrari SF-26
mzso wrote:
18 Feb 2026, 16:16
18 Feb 2026, 09:47
18 Feb 2026, 09:44
:shock:
What is?
https://imgbox.com/TkNikjyU
If you click the link it'll open the photo. This one is a shot of flow-vis on the Ferrari diffuser
SiLo
145
Re: Ferrari SF-26
mzso wrote:
18 Feb 2026, 16:16
18 Feb 2026, 09:47
18 Feb 2026, 09:44
:shock:
What is?
That's weird, I am in the UK and can see them fine.
Felipe Baby!
HungarianRacer
HungarianRacer
37
Re: Ferrari SF-26
18 Feb 2026, 16:18
mzso wrote:
18 Feb 2026, 16:16
18 Feb 2026, 09:47
What is?
It doesn't for me, the host he uses must be region-blocked.
mzso
mzso
75
Re: Ferrari SF-26
18 Feb 2026, 16:18
For me it just loads the same placeholder, upgrade-prompt image.
SiLo
145
Re: Ferrari SF-26
mzso wrote:
18 Feb 2026, 16:23
18 Feb 2026, 16:18
Who is your ISP? Do you have a VPN running?
Felipe Baby!
