Doesn't even need (0.52mm +++).Tommy Cookers wrote: ↑20 Dec 2025, 02:23this seems about rightBassVirolla wrote: ↑20 Dec 2025, 01:03Even without doing any numbers, a difference in stroke achieves an increase in displacement, and from the top of my head, after having assembled some engines, 7mm is HUGE. No way this is the number.
But talking about making a real engine, would make much more sense to calculate an increase in rod ratio or piston crown height to increase CR without increasing displacement.
Nevertheless, my numbers tell me:
(400cc + Combustion Chamber cc)/Comb. Ch. cc = CR
This gives me a combustion chamber of 26cc for CR = 16 and 23,5cc for CR = 18.
With the piston surface area, assuming a cylindrical combustion chamber, 4,7mm in height for CR = 18 and 5,2mm in height for CR = 16
0,5mm of difference with a long rod in some aluminum alloys is not too far fetched (even while thinking in an aluminum rod is quite a stretch).
Disclaimer: I can be wrong. Numbers quickly put in my kitchen whiteboard.![]()
(but the swept volume is 266cc not 400cc)
Al alloy has 13 ppm/deg F expansion (maraging steel and titanium both about 8 ppm Al/titanium about 10 ppm)
ie 200 deg F on a rod 200mm overall gives 0.52 mm thermal expansion
NO MYSTERY !!
EDIT
we must also consider the dimensional changes with temperature of the engine 'block'
this is presumably a low-expansion Al alloy in compression by a lot of high-tensile through-studs
the coolant temperature is rather low (lower than in road cars)
CR(cold) = ((1600/6) + x ))/x = 16 ; => x=17.778 cc
CR(hot) = ((1600/6) + y ))/y = 18 ; => y=15.686 cc
Irrespective of the shape of the 'head' of the compression chamber, this signifies a thin slice (vol x-y = 2.092cc) getting removed from somewhere near one of the ends of a cucumber. With a bore dia of 80mm (defined in the spec) means this cucumber slice is 0.416mm thick.
Can't they design a piston head with exotic materials that expands by 0.416mm when operating at optimal engine temp v/s when it's cold ? My guess is that such a thing already exists (for all its worth, the CR for the 2014 to 2025 era might be exceeding 18)
