2025 Scuderia Ferrari F1 Team
Luscion
Luscion
119
Re: 2025 Scuderia Ferrari F1 Team
Imola upgrades cant come soon enough
Xyz22
Xyz22
124
Middle sector slower than Ocon
SoulPancake13
SoulPancake13
Xyz22 wrote:
04 May 2025, 00:04
Haas didn't take the new front suspension for a reason I guess.
ScuderiaLeo
According to Duchessa, the anti-understeer setup Ferrari used performed better in the simulator than on track. The level of understeer on track was surprising to them.
deadhead
76
ringo wrote:
03 May 2025, 23:58
What he says is reasonable, but it still falls on the team to understand that they need to do something different to get the tyres in the right window. And even if in the correct window at the start of the lap..it needs to stay there for the rest of it. Fred is likely diverting attention to survive a few more weekends before upgrades.
What do you think happens when the tires are in the right window? P5 instead of P8?
Luscion
Luscion
119
ScuderiaLeo
I think this is the most dejected we've seen both drivers so far.
catent
I will continue to say it: this performance again suggests they're running the car higher than other teams (and probably losing dozens of points of downforce as a result).
Lack of pace on a wet track? Lack of pace on a green track? Poor traction and pace through low/medium-speed corners? They're running the car higher than they should be.
If that is indeed the case, how they managed to get something so fundamentally wrong from a chassis/suspension/weight distribution perspective in the final year of a regulation set, is hard to fathom.
catent wrote:
04 May 2025, 00:43
What's the fix?
They brought a modified floor and they still didn't address this.
Luscion
Luscion
119
catent wrote:
04 May 2025, 00:43
Autoracer have all but confirmed they are running the car a lot higher than they would like, even Lewis said it, 3mm higher than it should be,which is a lot and Autoracer said that their issue with the rear is aero related, which is better than it being a mechanical issue. i believe in one of Autoracer's streams they said the upgrades at imola aim to correct the weak rear end but im struggling to find it rn
https://autoracer.it/it/ferrari-risolve ... re-leclerc
Luscion
Luscion
119
Sevach wrote:
04 May 2025, 00:48
catent wrote:
04 May 2025, 00:43
What's the fix?
the floor upgrade they brought was never meant to solve their rear end issue, it was already in development before they found the issue with the rear. i believe their next set of upgrades at meant to address it (im looking for the autoracer stream)
Hammerfist
Hammerfist
Im so not looking forward to Monaco. A race they won last year. But with this car i dont think even leclerc will make top 10.
ScuderiaLeo
Luscion wrote:
04 May 2025, 00:53
Autoracer do not think the package will come in Imola. They're expecting Spain or later.
Maybe that will change because of this weekend's performance, Ferrari might accelerate the upgrades or something.
JPower
JPower
43
Hammerfist wrote:
04 May 2025, 01:03
That would be pretty shocking. I can't remember the last time Ferrari was that uncompetitive at Monaco. Maybe 2014?
For whatever reason, Ferrari tends to perform there regardless of how they do on "normal" circuits.
f1isgood
f1isgood
The issue is clear - the technical team has made a dud of a car. The drivers aren't primarily the point of concern as LEC will get mostly everything out of the car.
Just unbelievable really what I am seeing after the SF-24.
Call a spade, a spade.
