Mclaren Mercedes MP4-25
Holm86
261
Re: Mclaren Mercedes MP4/25
McLaren have had to make som adjustments to the floor to stand up to the new floor-flexi-test this weekend and according to Tim Goss they have actually made this into a performance gain. Anybody got any ideas on how???
mith
From what I've understood, they've stiffened splitter and at the same time added some minor tweaks.
raymondu999
747heavy wrote:
allstaruk08 wrote: Image
something like this wing with an f-duct - why not
Actually Red Bull started doing that around Turkey/Canada. Just not as extreme though.
失败者找理由,成功者找方法
close to what I had thought of ...I ´d think chord should be reduced towards the endplates and the wing should transform from twin element to single element at the outer extremes...
240
Funny enough that's approaching a renault "W" wing. The interaction between middle and end would be interesting.
Some more info on the F duct. It seems a whole new version was designed for monza.
Maybe one with a lower shark fin duct? and main element stalling instead?
Q: So you will use the F-duct this weekend?
TG: Yes, we’ll be running F-flap at some point on Friday and we’ll make the decision on Friday night as to whether we’ll race with F-flap or a conventional solution. We’ve developed both options for Monza. It’s not straightforward to get the F-flap to work on a low-downforce rear wing, but I think being the leaders in this technology we’re slightly better placed to get the most out of it.
Looks like they're trying to make it work for the low down force wing.
I'm expecting a very narrow shark fin duct. Similar to renault, that allows cross flow from both sides of the wing separated by the duct.
siskue2005
siskue2005
70
marcush. wrote:close to what I had thought of ...I ´d think chord should be reduced towards the endplates and the wing should transform from twin element to single element at the outer extremes...
wont that increase the cross section and so increased drag?
allstaruk08
allstaruk08
the lines i drew on it were just to show the shape of the wing better :)
raymondu999
The endplate looks almost 2-piece, a la BMW Sauber/MGP
失败者找理由,成功者找方法
240
could be a flexi wing. It has so many gaps between the pieces to allow for relative movement.
ell66
ell66
ringo wrote:could be a flexi wing. It has so many gaps between the pieces to allow for relative movement.
errr how about no.
is basically the same endplate that was first introduced back in spain.
240
You have pics for comparison?
Confused_Andy
Confused_Andy
I think that's the one from Spa that Hamilton ran, it was a flexi wing but a previous incarnation which was interesting.
bar555
bar555
Spa - Hamilton , Valencia’s spec front wing .
Spa Button , revised Silverstone's spec front wing with cascade winglets span reduction
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
Carmack
Mclaren had a pretty steep AoA in FP1 (one of the steepest, if not the) , while Mercedes GP and Lotus ran the lowest as far as I saw on TV...
