Mercedes W17
Lasssept
118
Re: Mercedes W17
Lasssept
118
Re: Mercedes W17
Xavier Gàzquez
InsaneX_Badger
Re: Mercedes W17
Lol the SLM button already worn out 😅
Re: Mercedes W17
Winged_One wrote:
12 Mar 2026, 04:04
12 Mar 2026, 01:10
07 Mar 2026, 13:01
Hollow wheel spokes
https://images.ps-aws.com/c?url=https% ... 0x742.jpg
How is the hollow spoke wheel manufactured? Is it cast?
I wouldn't want to cast that, it's all very thin, takes a lot of effort to get good quality on parts like that. My guess would be that it's welded together from multiple parts.
I believe these sorts of motorsport wheels are centrifugally cast.. Magnesium so not sure if that can be welded easily.
The hollow spokes appeared with Mercedes first for sure. Can't remember if it was 2012 or 2017 or sometime like that though!
les arcs
les arcs
Re: Mercedes W17
PlatinumZealot wrote:
14 Mar 2026, 22:14
Winged_One wrote:
12 Mar 2026, 04:04
12 Mar 2026, 01:10
Or a lost wax vacuum casting, definitely not a welded piece
michl420
michl420
Re: Mercedes W17
It is said that the front wing slm system is pneumatic in the mercedes. How could that be designed?
venkyhere
43
Re: Mercedes W17
michl420 wrote:
15 Mar 2026, 12:09
a plunger valve that interfaces when the nose and nose-stub come together, being part of the hydraulic lines from the chassis all the way to the front of the nose.
Y-250.A
Re: Mercedes W17
@iamuhammedkaya
Vappy
Vappy
Re: Mercedes W17
Did not know about the telemetry marker. Very cool
Lasssept
118
Re: Mercedes W17
:-k
I was noticing that all weekend, the Merc front wing was closing at different speeds depending on the corner, and that at it's slowest, it was closing in about 800ms, twice what the rules allow. This gif is slowed 4x and lines-up two corners on Russell's car where the wing closes much faster and much slower.
reddit
ScottB
ScottB
Re: Mercedes W17
Lasssept wrote:
16 Mar 2026, 11:00
:-k
https://i.postimg.cc/mkvS6vSm/8m56c0b2yapg1.gif
reddit
Wasn't their front wing system broken? Russell had one completely fail in Q2 I think, so might be reliability related rather than some sort of variable movement speed?
matt_s
matt_s
Re: Mercedes W17
I assume this is going to be like the compression ratio thing, How is the return timing measured - I assmue it's measured in parc-fermé conditions?
It's clear from that slo-mo that the car hits quite a severe braking bump just after SML deactivates, the force of which would be counteracting the force of the wing return mechanism. Whether that is the _only_ reason, I don't know.
EDIT: Good point from Scott on the broken FW.
michl420
michl420
Re: Mercedes W17
venkyhere wrote:
15 Mar 2026, 13:35
michl420 wrote:
15 Mar 2026, 12:09
Yes, thats part of it. But I mean primary, is there a seperate air compressor just for the front wing or has the engine such a air compressor for the valve system and the front wing cylinder is provided by this one?
And how big must be such a cylinder to bring the forces (and also the speed, which is a pneumatic "problem")?
Why they use a gas system and not a hydraulik one like on the rear wing?
Emag
Emag
137
Re: Mercedes W17
Lasssept wrote:
16 Mar 2026, 11:00
:-k
reddit
This doesn't seem desirable. Why would you want less front downforce while braking?
Probably a malfunction. Was it the same in the race as well?
Developer of F1InsightsHub
Stu
Re: Mercedes W17
14 Mar 2026, 22:14
Winged_One wrote:
12 Mar 2026, 04:04
12 Mar 2026, 01:10
I remember Reynard introducing hollow-spoke wheel in the heyday of CART (mid-nineties, IIRC).
