2026 Hybrid Powerunits
haza
haza
Re: 2025/2026 Hybrid Powerunit speculation
mzso wrote:
10 Jan 2026, 12:05
Vappy wrote:
10 Jan 2026, 00:36
The 2025 engines were relatively quiet overall unless you were directly behind the exhaust and not super far away. When the wastegate opened on the ferrari and honda, they would become noticeablly louder. I would say, in comparison, the sound from the 2026 engine in this video gives me some hope.
haza wrote:
10 Jan 2026, 00:56
Definitely louder you can hear the car through out the entire lap pretty much even distorts the audio on fly by
https://x.com/insideaudif1/status/20097 ... 77979?s=46
It sounds exactly the same as 2025's cars. No need to imagine things.
Engine notes is the similar yes but it is noticeably louder
Vappy
Vappy
mzso wrote:
10 Jan 2026, 12:05
Vappy wrote:
10 Jan 2026, 00:36
haza wrote:
10 Jan 2026, 00:56
The tone isn't different. How loud, i.e. audible it is - to me - sounds different. You're welcome to your opinion and i'm welcome to mine.
mzso
mzso
76
Vappy wrote:
10 Jan 2026, 13:16
And you're judging that based on low quality recordings? That's very much impossible.
Vappy
Vappy
mzso wrote:
10 Jan 2026, 15:33
Vappy wrote:
10 Jan 2026, 13:16
We can keep going back and forward, but as i'm not here to convince you, i'll simply respect we are at a respectable difference.
TeamKoolGreen
TeamKoolGreen
The sound of these engines is being overrated. Presumably because everyone's expectations were so low, since it is 50% Formula E after all.
If the MGU-H wasn't made illegal , everyone would be running them. Because the system weighs 8kg and allows the battery to be smaller. The lack of MGU-H also makes the car less efficient.
So there's a little something for nobody. The environmentalist fans get a less efficient car. And the purist racers get something heavier.
532
TeamKoolGreen wrote:
11 Jan 2026, 16:17
But the battery wasn't a lot smaller, if at all. 4kg difference for ES enclosure, though they may not be directly comparable, due to what was counted in the weight.
And even if it was, it would be because the output power was lower.
vorticism
vorticism
449
Tidbits:
-Rotational speed limit of the 2025 MGUH: 125,000rpm
-RS limit of the 2026 turboshaft: 150,000rpm
-RS limit of the 2025 MGUK: 50k rpm
-RS limit of the 2026 MGUK: 60k rpm
mzso
mzso
76
Since it always comes up, I wonder how the sound would change if there were more exhausts (and such turbos)?
Since the H was dropped there's no strong reason to use one exhaust. And wouldn't it be advantageous to have multiple, smaller turbos anyway? (I'm guessing 2 or 3 might be viable with a V6)
FW17
184
Why did the rules go backwards on the variable length intakes?
dren
228
FW17 wrote:
13 Jan 2026, 18:42
I'd wager cost/complexity.
Honda!
dren wrote:
13 Jan 2026, 18:48
FW17 wrote:
13 Jan 2026, 18:42
If you rephrased that to "The rules went backwards to lower complexity in a effort to curb costs and entice other PU manufactures" you'd be bang on!
They're also using "100% sustainable fuel", which they're interpreting to be ok to put that CO2 back into the air.
11 Jan 2026, 16:17
You could still argue that 100% of the power comes from the fuel... The battery is charged either by braking or by the ICE spinning the MGU-K, neither of which you can do without fuel to get you moving in the first place. It's not like you can finish a race with 50% of the power if you ran out of fuel!
mzso
mzso
76
diffuser wrote:
13 Jan 2026, 19:14
Well, as far as I remember they can charge the batteries for the start, so it's 99.x% :)
Marble
Marble
Hello !
Question for everyone : if my understanding is correct, the 8.5 MJ figure is regarding the maximum of energy which can be harvested by lap.
Does it mean that for a qualifying lap, if you start the lap with battery charged, then you can theoretically use 4MJ (stored in battery) + 8.5 MJ (assuming they can recover such an amount of energy).
I know it's really theoretical but I really want to understand if there is any limit on the electric energy which can be deployed (as opposed to harvested) during a quali lap.
Thanks for your contributions !
BorisTheBlade
50
Marble wrote:
15 Jan 2026, 07:06
Correct.
There is no deployment limit in the regulations. So you can deploy the 4 MJ from your full ES at the start of to lap plus whatever you are allowed and able to recover in the specific session on the specific track, as the 8,5 MJ are just a base value and not valid every time and everywhere.
