Packaging and, to a little amount, turbo lag is somewhat better to have twin turbos. But a single larger turbo is more efficient.mzso wrote: ↑13 Jan 2026, 03:15Since it always comes up, I wonder how the sound would change if there were more exhausts (and such turbos)?
Since the H was dropped there's no strong reason to use one exhaust. And wouldn't it be advantageous to have multiple, smaller turbos anyway? (I'm guessing 2 or 3 might be viable with a V6)
a single larger turbo is more efficient only if the exhaust pulses (waves) have by design been cancelled (not preserved)BassVirolla wrote: ↑15 Jan 2026, 10:51Packaging and, to a little amount, turbo lag is somewhat better to have twin turbos. But a single larger turbo is more efficient.
While I can and should aknowledge it, it's just true for the turbine. For the compressor, still better one big than two small.Tommy Cookers wrote: ↑15 Jan 2026, 11:20a single larger turbo is more efficient only if the exhaust pulses (waves) have by design been cancelled (not preserved)BassVirolla wrote: ↑15 Jan 2026, 10:51Packaging and, to a little amount, turbo lag is somewhat better to have twin turbos. But a single larger turbo is more efficient.
we stopped doing that 50 years ago
preserved exhaust pulses can significantly or substantially drive the turbo without back pressure
ok 2026 F1 has unusually high expansion ratio and unusually lean AFR so turbine work relative to demand will be low
a V6 is crying out for 2 turbos
because the exhaust pulses are ideal with each bank of 3 cylinders having its own turbo
(ok slightly less than ideal with a 90 deg V6)
Thus, it should be noted that pure pulse turbocharging requires a turbine size which has to be designed only for the single cylinder displacement, while a pure constant pressure turbocharging requires a turbine size depending only on the total displacement of the engine.Tommy Cookers wrote: ↑15 Jan 2026, 11:20a single larger turbo is more efficient only if the exhaust pulses (waves) have by design been cancelled (not preserved)BassVirolla wrote: ↑15 Jan 2026, 10:51Packaging and, to a little amount, turbo lag is somewhat better to have twin turbos. But a single larger turbo is more efficient.
yesBassVirolla wrote: ↑15 Jan 2026, 15:03Thus, it should be noted that pure pulse turbocharging requires a turbine size which has to be designed only for the single cylinder displacement, while a pure constant pressure turbocharging requires a turbine size depending only on the total displacement of the engine.
https://link.springer.com/article/10.10 ... 19-00048-8
....the speed component of the exhaust pressure amounts to less than a 2% (while talking about turbine work).
So, probably tuned length exhausts in F1 are more related to cylinder scavenging than turbine work.
I'd say they're for improving *both scavenging and pulse velocity--which is the greater beneficiary I'm not sure. In a log manifold the pulse is expanded across the shared volume of the log rather than directed exclusively toward the turbine. Some of the initial F1 turbo-hybrid engines had log manifolds which to me suggests scavenging wasn't necessarily an issue as boost pressure and valve overlap could clear out the cylinder; use of Miller-cycle would support such a pressure gradient existing during overlap. Log manifolds are smaller and lighter, which may have been the initial use case.BassVirolla wrote: ↑15 Jan 2026, 15:03So, probably tuned length exhausts in F1 are more related to cylinder scavenging than turbine work.
Mercedes used log style manifolds in the first year of the turbo hybrid era, I think they chose this for space optimization. They also sounded quite different.vorticism wrote: ↑15 Jan 2026, 20:41I'd say they're for improving *both scavenging and pulse velocity--which is the greater beneficiary I'm not sure. In a log manifold the pulse is expanded across the shared volume of the log rather than directed exclusively toward the turbine. Some of the initial F1 turbo-hybrid engines had log manifolds which to me suggests scavenging wasn't necessarily an issue as boost pressure and valve overlap could clear out the cylinder; use of Miller-cycle would support such a pressure gradient existing during overlap. Log manifolds are smaller and lighter, which may have been the initial use case.BassVirolla wrote: ↑15 Jan 2026, 15:03So, probably tuned length exhausts in F1 are more related to cylinder scavenging than turbine work.
Why would they throw it away?Tommy Cookers wrote: ↑15 Jan 2026, 19:41yesBassVirolla wrote: ↑15 Jan 2026, 15:03Thus, it should be noted that pure pulse turbocharging requires a turbine size which has to be designed only for the single cylinder displacement, while a pure constant pressure turbocharging requires a turbine size depending only on the total displacement of the engine.
turbocharging is the dutiful son of the (so-called) Diesel engine, its practicalities, and the exhaust gas thereof
preserving the exhaust 'pulses' is in principle unrelated to 'tuned length' exhausts
as WW2 and later piston-engined aircraft showed
either the 'TurboCompound' (18 pipe 3 turbine recovery power driving the crankshaft/propeller shaft) ....
or direct momentum addition to the ambient air by entrainment ('jet effect') - 12, 14, 18 or 24 'stub' pipes 'fishtailed'
either was 'free' power - not power gained by increasing mass flow of air and fuel
there was no backpressure (except when engineered to enhance jet thrust for some particular situation)
Pinkel of the NACA Lewis Propulsion Laboratory c. 1941 was the real brains in this field ....
all the rest were blinkered and wrong in their thinking
of course the engines all had eg 6 or 7:1 CR to allow high boost for high takeoff power ....
so there was a lot of energy potential left in those pulses
by 2015 all the F1 engines had already or adopted the 'pulse tuned length' exhaust system
for 2026 will they throw away this seemingly 'free power' ?
Uneven lengths for even pulse spacing.Holm86 wrote: ↑15 Jan 2026, 22:13Mercedes used log style manifolds in the first year of the turbo hybrid era, I think they chose this for space optimization. They also sounded quite different.vorticism wrote: ↑15 Jan 2026, 20:41I'd say they're for improving *both scavenging and pulse velocity--which is the greater beneficiary I'm not sure. In a log manifold the pulse is expanded across the shared volume of the log rather than directed exclusively toward the turbine. Some of the initial F1 turbo-hybrid engines had log manifolds which to me suggests scavenging wasn't necessarily an issue as boost pressure and valve overlap could clear out the cylinder; use of Miller-cycle would support such a pressure gradient existing during overlap. Log manifolds are smaller and lighter, which may have been the initial use case.BassVirolla wrote: ↑15 Jan 2026, 15:03So, probably tuned length exhausts in F1 are more related to cylinder scavenging than turbine work.
But does equal length manifolds really make sense in an odd fire engine?? A 90° V6 with shared crank pins fires in a 90-150-90-150-90-150 order, wouldn't unequal length exhaust pipes make it possible to space out exhaust pulses more even at a given RPM?? Has any team tried this??
Without wanting to sound stubborn or defying... Just truly curious and with an insatiable appetite for learning... Probably steaming from my liking for tuning turbo diesel engines.Tommy Cookers wrote: ↑15 Jan 2026, 23:24what I write whenever this topic comes up ......
each bank and its 3 equal branch manifold is an island (of equal 240 deg firing)
what matters is to make the pipes beyond each manifold different to each other in length
by enough to compensate for the inequality in firing times (this can only be exactly correct at one rpm)
about 20 cm difference IIRC
the early Renault turbo F1 did this (for about 18 months before the twin turbo came along)
"Cylinder efficiency or maximum blowdown"BassVirolla wrote: ↑15 Jan 2026, 23:53Without wanting to sound stubborn or defying... Just truly curious and with an insatiable appetite for learning... Probably steaming from my liking for tuning turbo diesel engines.Tommy Cookers wrote: ↑15 Jan 2026, 23:24what I write whenever this topic comes up ......
the early Renault turbo F1 did this (for about 18 months before the twin turbo came along)![]()
- What do you think is better in the general picture: Tuned lengths for cylinder efficiency or a manifold made to retain / improve blowdown / pulses?
- Why 3 cylinder better than 4 (or 2) per bank? What makes you say that 3 is the ideal number?
