2026 Hybrid Powerunits
FW17
189
Re: 2025/2026 Hybrid Powerunit speculation
wuzak wrote:
18 Jan 2026, 10:48
FW17 wrote:
18 Jan 2026, 10:20
wuzak wrote:
18 Jan 2026, 10:03
Was it?
Where is the source for that?
Dont know the source, but a lot of online chatter on RA621H being 1014hp
which would be close to 59-60%
That'd be with battery assistance.
You can't count battery assistance in teh thermal efficiency calculation.
1014hp = 854hp from ICE.
Which is about 51% TE for the ICE.
Which is what you said.
Turbo-compounding would not give 160hp to the MGUK without battery assistance.
Numbers are clouded on how much the MGU H could generate, so let us say it generated its capacity
saviour stivala
saviour stivala
43
The type of turbo compounding used by the formula 1-2025 power unit, ''ETC'' - electric turbocharger, which was a totally different type of compounding to the turbo compounding ''mechanical turbo compounding'' used by the Wright aero engine, could add 160 HP to the crankshaft, and unlike the Wright system, it did not required an extra blow-down exhaust turbine.
Stu
wuzak wrote:
18 Jan 2026, 09:25
FW17 wrote:
18 Jan 2026, 08:46
wuzak wrote:
18 Jan 2026, 08:12
With turbo-compounding?
What compounding?
The maximum efficiency was when the MGUH fed power directly to the MGUK.
This is turbo-compounding.
@FW17 - turbo compounding is different to compound turbo-charging.
532
Stu wrote:
18 Jan 2026, 17:11
wuzak wrote:
18 Jan 2026, 09:25
FW17 wrote:
18 Jan 2026, 08:46
What compounding?
I think this is the one you should be responding to:
djos wrote:
18 Jan 2026, 09:49
In not sure you understand the definition of the word compounding, you can’t compound a turbo without a second turbine!
Bill
Bill
Some teams are experiencing fuel combustions problems with there engine and have ask for some concessions from fia to run fuel that has not been homologated during testing.so why are the media not reporting on these and follow up the story do some digging and identify who these are.do some real reporting not lazy click bait thing maybe they are afraid of what they may find maybe it will conflict with the prevailing narrative that a particular manufacturer is going to dominate.
532
Bill wrote:
18 Jan 2026, 17:41
Combustion or production issues?
Bill
Bill
wuzak wrote:
18 Jan 2026, 18:01
Bill wrote:
18 Jan 2026, 17:41
Both the engine are sensitive to very small variations in fuel quality
gearboxtrouble
gearboxtrouble
Bill wrote:
18 Jan 2026, 17:41
I read that this was because there was a manufacturing constraint for the Barcelona test. My guess is its Mercedes/Petronas because they have 4 teams to supply and Petronas just isn't in the same league as the other fuel suppliers who have decades of R&D and tens of billions invested in sustainable fuels.
Bill
Bill
The only news in town that the mercedes are going are going to blow the socks out of everyone. so if Petronas are having some trouble how did the media come to that conclusions
Hoffman900
Hoffman900
243
Bill wrote:
18 Jan 2026, 19:55
About the same way any of us, throwing at a dart board. The manufacturers aren’t running to to the media with anything.
FW17 wrote:
18 Jan 2026, 09:52
wuzak wrote:
18 Jan 2026, 09:25
FW17 wrote:
18 Jan 2026, 08:46
What compounding?
With compounding of MGU H it was 59%
51% was only from ICE
No. The MUGH considered part of the ICE. This is everything part of the fuel to shaft energy loop in steady state. It was about 52% to 53% thermal efficiency.
There is no more waste heat recovery in 2026.
I have to check back the 2014 engine threads but I believed total ICE power was around 840hp or 620kW. We calculated the MGUH at something like 60kW to 100kW i do not remember right now. But expect these new engines to be less thermally efficient.
I hear the 470kW being bandied about by posters here... And they are saying 1100hp (820kW total?) and if 350kW is MGUK that 470kW (630hp) does make sense, maybe on the lower side of things. It's fair to say weaker by about 150hp to 200hp?
Thermal efficiency would drop to 40%. (max out maybe 43%)
579
saviour stivala wrote:
17 Jan 2026, 20:33
vorticism wrote:
17 Jan 2026, 19:46
17 Jan 2026, 18:23
Re your persistence colossal mix-up of the Wright turbo compounding by the use of a ''BLOW-DOWN TURBINE'' with that of the Formula 1 turbocharger ''PRESSURE TURBINE''.
The MGUH-era turbo was both as evidenced by the existence of both tuned headers and wastegates on those engines. You made a blanket statement about "the turbocharging process" requiring backpressure, which is what Tommy countered.
The MGU-H- ERA turbocharger turbine used in formula 1 is a pressure turbine type and not a blow-down type of turbine, no matter what you and T C says. If it wasn't a pressure type of turbine, a wate-gate would not be used.
The turbine used in F1 utilises both pressure and blowdown pulses. Have you heard of a company call GARRETT? They know a thing or two about turbochargers. Here is an article posted on their website. https://www.garrettmotion.com/wp-conten ... vanced.pdf
(From page 5 and 6)
A design feature that can be common to both manifold types is a " DIVIDED MANIFOLD" , typically employed with " DIVIDED " or "twin-scroll" turbine housings. Divided exhaust manifolds can be incorporated into either a cast or welded tubular manifolds. The concept is to DIVIDE or separate the cylinders whose cycles interfere with one another to best utilize the engine’s exhaust pulse energy.
For example, on a four-cylinder engine with firing order 1-3-4-2, cylinder #1 is ending its expansion stroke and opening its exhaust valve while cylinder #2 still has its exhaust valve open (cylinder #2 is in its overlap period). In an undivided exhaust manifold, this pressure pulse from cylinder #1’s exhaust blowdown event is much more likely to contaminate cylinder #2 with high pressure exhaust gas. Not only does this hurt cylinder #2’s ability to breathe properly, but this pulse energy would have been better utilized in the turbine. The proper grouping for this engine is to keep complementary cylinders grouped together-- #1 and #4 are complementary; as are cylinders #2 and #3.
Because of the better utilization of the exhaust pulse energy, the turbine’s performance is improved and boost increases more quickly.
saviour stivala
saviour stivala
43
gruntguru wrote:
19 Jan 2026, 04:54
17 Jan 2026, 20:33
vorticism wrote:
17 Jan 2026, 19:46
(From page 5 and 6)
Yes. Agree that the 'twin-scroll' exhaust turbine housing design minimizes the effect of mixing all exhaust pulses into one collector, by dividing said pulses into two collectors. As the formula 1 ICE is a V-6 cylinder, using a twin-scroll exhaust turbine housing means that two sets of three selected cylinders will each blow their respective exhaust gas through a primary, with all three primary in the set pumping into a collector, with each of the two collectors pumping into the nozzle aimed at the turbine. The system of multi primaries (more than one) pumping into a collector with the collector pumping into the turbine nozzle aimed at the turbine, will still render the exhaust turbine a 'pressure turbine'. The fact that a variable opening waste-gate is used, provides the exhaust gases from cylinders to turbine with two paths, when the waste-gate is opened exhaust gas pressure is at atmospheric pressure, and no turbine recovery is possible, When it is closed, exhaust gas is above atmospheric pressure and turbine recovery is possible.
FW17
189
470kw from ICE would be over 56%
19 Jan 2026, 06:30
gruntguru wrote:
19 Jan 2026, 04:54
17 Jan 2026, 20:33
(From page 5 and 6)
It uses some form of pulse effect because they would all stay with log manifolds if it were only a pressure turbine.
The exhaust lengths do indeed seem to be tuned, and notice each runner meets at nearly zero degrees to minimize pulse blow-back.
