Khamsin Virtual Racecar Challenge 2015
RicME85
52
Re: Khamsin Virtual Racecar Challenge 2015
Stop 'tweaking' the rules, it just makes a mockery of the competition.
Save the changes for next year.
MadMatt
MadMatt
125
People needing inspiration can take a look at these 2 examples!
http://www.f1technical.net/forum/viewto ... f=5&t=9635
https://grabcad.com/library/le-mans-study
I'm not saying its good or bad, but something created from scratch!
MadMatt
MadMatt
125
Also one more precision regarding K4.1.
When saying 10° downward and 20° upward, I am not sure what is your reference point. I will use simple words here because I want to be sure everybody understands, so when looking down the X axis, is it 20° clockwise and 10° anti-clockwise?
In maths I would say +10° and -20° (just to be clear).
RicME85
52
Correct its positive and negative
julien.decharentenay
MadMatt wrote:Is there are way I could be used to do the simulation work without being able to look at other people's design?
Unfortunately I can't see how to achieve this... The other issue is to put the framework in place to allow for the simulation to be conducted in an easy fashion. I will release later today an updated version of OCCFD with a slightly refined mesh - the mesh size at the wings will be 3mm and 6mm at the body. It is as fine I will be able to make it...
MadMatt
MadMatt
125
No problem Julien. And thank you for the mesh update, that's great news, I will give it a try! :)
CAEdevice
52
I was thinking about this and I reached the conclusion that If someone (let's call him "a") has not the possibility to run a simulation, he could ask MadMatt (or CAEdevice or "b") to run the simulation. They would have both an advantage: "a" would have the geometry checked/tested, and "b" could bring oxigen to his ideas looking at someone other car.
I did the same last week asking MadMatt (thanks) to run a model of mine, and during 2014 I helped in the same way on of the partecipants.
cdsavage
cdsavage
19
A copy of the test car is available here: http://www.mediafire.com/download/sar9z ... xample.zip. Again, this car doesn't conform to the current rulebook, I'm posting it mainly to make it clear how the model should be prepared before submitting.
MadMatt wrote:When saying 10° downward and 20° upward, I am not sure what is your reference point. I will use simple words here because I want to be sure everybody understands, so when looking down the X axis, is it 20° clockwise and 10° anti-clockwise?
Rotation of 0 would mean that the inlet surface is facing directly forward. Rotation 'upward' would mean that the surface now faces forward and upward. I think the phrase 'looking down the x-axis' could be interpreted in different ways, but when the left-hand side of the car is facing the viewer, rotation upwards would be clockwise.
CAEdevice wrote:I was thinking about this and I reached the conclusion that If someone (let's call him "a") has not the possibility to run a simulation, he could ask MadMatt (or CAEdevice or "b") to run the simulation. They would have both an advantage: "a" would have the geometry checked/tested, and "b" could bring oxigen to his ideas looking at someone other car.
It is a great idea... But it is between "a" and "b", which are both participants (ie not KVRC organiser). How can we (as KVRC organiser) facilitate this?
RicME85
52
Im trying to look at OCCFD out of curiosity.
On the KVRC site it says ImageMagick-6.8.6-Q16, I cannot find a download of that specific name, everything I have found that starts ImageMagick-6.8.6 has another number before Q16. Which should I use?
Paraview - with version? I have seen mentions of 3.98 and 4.1 in this thread
CAEdevice
52
I think that the release of OCCFD is helping vert much everyone.
Another step could be to allow a free CFD run to all the partecipants or a test race without points (as you already proposed).
But at the end it is a CFD competition, quite difficult to imagine to take part with no CFD resources at all.
RicME85
52
Anyone had OCCFD fail on them straight away with :
Tool convert can not be found. We are unable to process the request further.
Backtrace: C:\Users\Richard\AppData\Local\Temp\ocrD764.tmp\src\mainOneClickCFDVehicle.rb:231:in 'block in checkTools'
OCCFD v1.0: Sorry to give you a bad news update. I have to rework it a bit as I noticed that I am hitting some mesh size limitations with the current Amazon AWS setup. I am considering my options prior to making a final decision and release a final v1.0... Sorry about this.
MadMatt
MadMatt
125
RicME85 wrote:Im trying to look at OCCFD out of curiosity.
I think if you use the latest version of ImageMagick it should work (at least its the version I've got and it works): http://www.imagemagick.org/download/bin ... 64-dll.exe
For Paraview, you can use either I think, Julien made it possible, but if you can, use 4.1.
