Mclaren MCL40
SilviuAgo
184
Re: Mclaren MCL40
Front suspensions in 2025 πŸ†š front suspensions in 2026 by the race.
venkyhere
45
Re: Mclaren MCL40
Gridlock
42
Re: Mclaren MCL40
From testing coverage, as far as I can tell, McLaren seem the only team intent on leaf-blowering the "driver cooling" hole in the very front, even when there's also a cooling hose directly into the cockpit Β―\_(ツ)_/Β―
#58
LionsHeart
LionsHeart
Re: Mclaren MCL40
Gridlock wrote: ↑
13 Feb 2026, 18:34
I assume they cool the system that activates the upper flaps. There's no other point. There's nothing else to cool in that area when the car is in the pits. Or maybe the McLaren drivers have very hot feet. :D
_cerber1
302
Re: Mclaren MCL40
Re: Mclaren MCL40
Beware of T-Rex
Emag
Emag
137
Re: Mclaren MCL40
They closed off the cooling slots?
Developer of F1InsightsHub
Re: Mclaren MCL40
Emag wrote: ↑
13 Feb 2026, 23:24
The "new" one has no chimney, but a larger opening in the back. The "old" one has a smaller rear exit, but with cooling chimney on the sharkfin area. For now I would assume simple test items, rather than any permanent change.
Beware of T-Rex
Emag
Emag
137
Re: Mclaren MCL40
AR3-GP wrote: ↑
13 Feb 2026, 23:30
Emag wrote: ↑
13 Feb 2026, 23:24
Ah true, I missed the expansion of the opening. Agreed, probably just testing different engine covers.
Re: Mclaren MCL40
Farnborough wrote: ↑
12 Feb 2026, 09:09
AR3-GP wrote: ↑
12 Feb 2026, 01:43
Mclaren moves the entire flap including the center section when they activate the active aero.
https://i.postimg.cc/zf9C0bt3/image.png
The repair patch looks like they've experienced too much movement or signifying a minor level of integrity failure local to that wing mount pylon.
You can see how much the mainplane flexes at the moment that the active aero opens and closes in this hot lap .Watch the left side in front of the halo.
Therefore I am not surprised that Mclaren required additional reinforcement at the connection of the pylons to the nose.
Beware of T-Rex
Re: Mclaren MCL40
SilviuAgo wrote: ↑
11 Feb 2026, 16:37
Diffuser comparison:
https://pbs.twimg.com/media/HA4P1H1bQAA ... ame=medium
Source: Fulvio Vigilante
I think people confused the higher positioned lower brake duct winglet on the McLaren as forming a wide gaping mousehoule. I am even now questioning if the car even has any mousehouse at all.
Emag
Emag
137
Re: Mclaren MCL40
PlatinumZealot wrote: ↑
14 Feb 2026, 12:06
SilviuAgo wrote: ↑
11 Feb 2026, 16:37
I think this β€œdebate” was already settled. There were some angles that were a bit confusing, but with better pictures later on it was cleared. McLaren don’t have the diffuser cut.
Re: Mclaren MCL40
Interesting. There is no mouse hole. What I see is they have raised the lower edge of side wall of the diffuser to introduce energy in a different way from the mousehoule. The walls of the rear brake ducts are also serve as either a side expansion of the diffuser or just opening some area to manage vortices better. But either way it is not a mousehole but a diffrent approach to maximizing the energy and volume of the diffuser.
_cerber1
302
Re: Mclaren MCL40
=P~
SilviuAgo
184
Re: Mclaren MCL40
