Tommy Cookers wrote: ↑25 Jan 2026, 18:57
Schumix wrote: ↑25 Jan 2026, 16:37
... What Mattia Binotto is revealing is deplorable for the sport.
Could someone explain .... why these PUs that manage to circumvent the 16:1 ratio are deemed compliant in 2026? ...
Ferrari's PU in 2019 complied with the regulations... but not with the spirit of the regulations...
could someone explain how the 2026 Ferrari doesn't exceed 16:1 at the design rpm and temperature ....
when at such rpm rods and crankshaft at TDC deflect upwards so as to increase significantly CR above the static CR
(as has been posted in another thread)
at TDC before the power stroke and 12000 rpm ......
the rod will be 0.4 mm longer due to c.4 tons (inertial-pressure) load on the rod (piston&rod mass 1200 gm) ....
and the crank will be eg deflected up at the big end journal adding (a guess) 0.2 mm to the above ....
giving to a 'running' geometric CR of 19:1 in an engine with 'bathtub' combustion chamber and 16:1 nominal CR
(a deflection far less than in Austin 7 engines that eg Colin Chapman and Eric Broadley used in their 750 MC days)
thermal expansion effects on CR are nil if all the parts have the same expansion coefficient and temperature
yes the thermal expansion could reduce (or increase) the 19:1 CR depending on the metals used for each part
