2026 Hybrid Powerunits
Hoffman900
Hoffman900
243
Re: 2025/2026 Hybrid Powerunit speculation
They weren’t utilizing incomplete cylinder filling, they are ramming the air in with a ton of boost, that’s a design feature of the Miller Cycle and pretty much the only way it can work.
vorticism
vorticism
449
Utilizing only a portion of a cylinder's displacement (swept volume) to define the intake charge would be incomplete filling in terms of displacement utilized, via valve timing, and regardless of boost pressure or the absence of it (Atkinson). That's where the advantageous asymmetry arises from--the expansion ratio being greater than the compression ratio.
Hoffman900
Hoffman900
243
vorticism wrote:
08 Feb 2026, 23:19
Utilizing only a portion of a cylinder's displacement would be incomplete filling in terms of displacement utilized, via valve timing, and regardless of boost pressure or the absence of it (Atkinson). That's where the advantageous asymmetry arises from--the expansion ratio being greater than the compression ratio.
The advantage is the over expansion allowing for a cooler charge at time of ignition, allowing for greater knock control, thus allowing for more cylinder pressure for a given fuel (which the rules limit).
This allows for more boost. Since the engines are fuel limited (flow and chemistry - per rules), they’re on the edge of knock the entire time.
In a fuel limited format, you work really hard to prevent knock. It’s quicker to run a constant boost / varying lamba than it is a varying boost / constant lamba. There is a really good dossier on the Audi DTM engine in Race Engine Technology from some years ago that explains this better.
Rikhart
Rikhart
39
Great video by Yellistener, I just can't wrap my head around how weird and artificial this will feel.
vorticism
vorticism
449
Hoffman900 wrote:
08 Feb 2026, 23:25
vorticism wrote:
08 Feb 2026, 23:19
Not what I was getting at. I made a general statement about what defines the Miller cycle. Check the preceding posts.
peewon
Rikhart wrote:
10 Feb 2026, 13:30
Absolutely bizarre that this formula was allowed to continue unchanged despite early warnings from multiple teams.
FittingMechanics
FittingMechanics
I'm not convinced it will look like that. Looking at speeds in Bahrain you don't see this slowdown at the end of straights. It may be more noticeable at less energy rich tracks.
Rikhart
Rikhart
39
FittingMechanics wrote:
11 Feb 2026, 11:12
Apparently this track is not representative because it's great to harvest energy, see this post:
viewtopic.php?p=1323148#p1323148
Would teams use the MGU-K to suppress the crankshaft torque for milliseconds during the gear change? Could that extract any meaningful amount of energy over a lap? Probably not worth much.
Beware of T-Rex
671
on every upshift the K dumps a good fraction of the PU's rotational KE to the ERS (and fuel-burn in 200 msec window)
though it uses some electricity to help the PU rpm match the needs for down-shifting, then resumes regen
BorisTheBlade
50
11 Feb 2026, 21:57
I honestly have no clue, how much accumulated time is spent during shifts - is it in the range of 1-2s per lap? With a technical best-case that could be worth roughly 700 KWs or 8% of the max budget per lap - not nothing in F1.
If (big if) one Team had such an advantage, it could be significant for race pace on an energy starved track.
But as Bahrain is not such a track and as I have faith in at least some of the others to not have failed miserably with "ordinary" recovery, they might just be on different programmes.
Otherwise, Melbourne could be a blood bath come raceday.
johnnycesup
johnnycesup
F1 cars have seamless shift gearboxes, and pretty fast ones at that IIRC. I don't think trying to harvest in upshifts is worth the trouble to be honest.
671
johnnycesup wrote:
11 Feb 2026, 22:39
it's free electricity
it's a doddle
the 'seamlessness' of an up-shift done any other way is an illusion
(energy flow rate is cut pre-shift & dumped in the transmission string - worse, PU inertia is far greater than in older cars)
mzso
mzso
75
BorisTheBlade wrote:
11 Feb 2026, 22:36
Others compared to who?
I have no idea if there's any connection to Red Bull. I was just curious if it's something that a team would do. IIf you were going to cut the fuel, then you should harvest for a split second instead. I also wonder how well the FIA sensors detect short burst of current and/or torque spikes. There could be recoverable energy hidden in the "noise".
Beware of T-Rex
