![Image](http://24.media.tumblr.com/e7bd63426fd51a1007898a91a94125d5/tumblr_n4c4c88XDu1sncaa3o1_400.gif)
Take a look at Rosbergs Pole lap from Bahrain....Hail22 wrote:Vettels 3rd place lap... "Oh I seem to be out of the confines of the circuit"
http://24.media.tumblr.com/e7bd63426fd5 ... o1_400.gif
I think I may be on to something about vettel. Is he a "light braker"? It seems his style is to brake lighter than others and leave downforce to generate the rest of the bite for turn in. When it works, he runs wider out of the apex than most drivers but exits with higher speed. This might explain why he turns in early because without enough weight transfer to the front tires from braking, you aren't going to generate the needed grip to make a quick enough turn in to hit the apex.....simply to drive like he does, you have to have started turning in earlier. This also supports that consensus in the paddock that during the blown diff. period he'd slide the back out (brake bias/differential settings) then stop it by "blowing". This slide is not to be confused with the normal rotation from having a planted front and loose rear induced by harsher braking.Hail22 wrote:Vettels 3rd place lap... "Oh I seem to be out of the confines of the circuit"
I've noticed the same. Lewis made a remark about in a couple of years ago during the Indian GP. Nico's Pole lap in Bahrain was also clearly off the track with all four wheels.SiLo wrote:IMO he is always running off track or over the white lines to gain an advantage, more than any other driver. I notice it all the time when watching him (in the dry) and it bugs me that he can get away with it every time. The other drivers can go just as fast or faster and remain within the confines of the track, so why can't he?
They don't, you just don't see it because it's not aired more often than it is. I remember the same stuff floating around back in india 2012 when vettel's pole lap was shown and he was off the track 2 times with all 4 wheels and everyone was making a big fuss how his pole should be stripped from him and so on. Everyone was doing it of course, but people chose to selectively point out that only vettel did it. The usual stuff.SiLo wrote:IMO he is always running off track or over the white lines to gain an advantage, more than any other driver. I notice it all the time when watching him (in the dry) and it bugs me that he can get away with it every time. The other drivers can go just as fast or faster and remain within the confines of the track, so why can't he?
That's supposed to be the rule, but as you can see its not always enforced...Shrieker wrote:Doesn't the rule say your lap's invalid if you've put all 4 wheels off the track(white lines) ?
I also thought there was a minimum 2 wheels inside the white line rule?Shrieker wrote:Doesn't the rule say your lap's invalid if you've put all 4 wheels off the track(white lines) ?
Nope, there's a minimum "some car" inside the white line rule.djos wrote:I also thought there was a minimum 2 wheels inside the white line rule?Shrieker wrote:Doesn't the rule say your lap's invalid if you've put all 4 wheels off the track(white lines) ?
Precisely. Meaning if you cut it just the correct amount - and the front of the car rejoins the track before the rear leaves the track confines - then you're in the green.Shrieker wrote:Doesn't the rule say your lap's invalid if you've put all 4 wheels off the track(white lines) ?
