Red Bull RB22
Owen.C93
Owen.C93
189
Re: Red Bull RB22
13 Feb 2026, 22:12
The slot in the diffuser wall looks like this:
https://i.postimg.cc/ry5FCMNY/image.png
venkyhere
43
Re: Red Bull RB22
white indicates the diffuser 'hole'.
Not getting a proper impression of the orange marked area :
(a) is it a ramp that rises abruptly (single orange arrow) from the floor's roof and is the top surface of the diffuser itself
OR
(b) the diffuser originates upstream of this and the roof of the diffuser is 'underneath' the 'floor-ramp' junction we can see here
Also, the 'line' shown by the double orange arrows - it remarkably looks like a stair-step, but I am hoping it's the shadow from something above
Re: Red Bull RB22
Red Bull has been running with this semi-permanent pressure sensors on the floor in the coke bottle area. Someone pointed out that Red Bull removed the left side barge board on both thursday and friday evening. They could be studying how well the bargeboard is working to exclude the tire wake.
#ReleasetheADUO
Re: Red Bull RB22
The Red Bull (and Vcarb) are using a spoke-less wheel rim on both front and rear according to Scarbs (@ScarbsTech). https://x.com/ScarbsTech/status/2022612 ... 42/photo/4
Solid face. Very interesting. Some other teams have gone for traditional spoked wheel rim with composite covers, but this limits heat transfer to the surroundings. Now they have direct metal to air heat conduction, just like a radiator.
#ReleasetheADUO
joseff
Re: Red Bull RB22
The ghost of Colin Chapman approves.
carisi2k
29
Re: Red Bull RB22
venkyhere wrote:
13 Feb 2026, 22:44
Someone help me understand about the 'ROKT' shoulder cannon beneath the halo :
1) is it a cooling duct (looks likely despite how narrow it is) or an aerodynamic pipe-duct to re-energize the flow at the side of the engine-cover-waterslide area ?
2) irrespective of whether it is cooling/aero, where is the air inlet ? unable to locate it in the high-res pictures 2.3.4. Kindly help locate. Is the inlet same as the main sidepod inlet itself ?
https://i.ibb.co/d4hswHkD/RB22-shoulder-cannon.png
From my understanding that bulge might not be for how you think it is used. Unless I am mistaken there was a photo earlier in the thread showing that the rb22 still has an air to air intercooler and that piping might be for routing air internally and not for an exhaust where the gills are.
Badger
Badger
46
Re: Red Bull RB22
Re: Red Bull RB22
Nicolas Carpentiers - RB22 rear brake ducting:
Rb20 and rb21 had superficially similar caketin internals
Rb21 for comparison:
Owen.C93
Owen.C93
189
Re: Red Bull RB22
Any idea what this component is that's circled? Looks detached from the usual heave spring and anti-roll bar. Just curious.
vorticism
vorticism
449
Re: Red Bull RB22
vorticism wrote:
04 Feb 2026, 18:38
vorticism wrote:
01 Feb 2026, 22:11
vorticism wrote:
30 Jan 2026, 21:37
✅sidepod as front floor extension (only RBR so far, in part) viewtopic.php?p=1298371#p1298371
Looks like I was conservative. The forward sidepod overhang appears to comprise the inner half of the sidepod, the entirety of the inlet area. It’s bridging the forward chassis to the floor in a more gradual way and effectively increases the plan area of the floor as well as its inlet height, beyond what could be achieved otherwise (with a more typical undercut sidepod). A remarkable departure from ~15 years of standard practice.
What I hinted at last year.
Sidepod as FLEX: viewtopic.php?p=1298371#p1298371
Forward oriented blunt-faced sidepod: viewtopic.php?p=1313121#p1313121
Confirmed:
Re: Red Bull RB22
vorticism wrote:
16 Feb 2026, 16:35
vorticism wrote:
04 Feb 2026, 18:38
https://i.postimg.cc/PJgkGp9m/RB22FLEXvorticism-A.jpg
Confirmed:
https://i.postimg.cc/cCVXBdXb/rb22overh ... icism2.jpg
Now that it's confirmed, is it possible to discuss the possible advantages, and the reasons they've gone for this approach over Audi's?
vorticism
vorticism
449
Re: Red Bull RB22
Audi's looks more aggressive to me. Taller, with a snowplow shape that pushes air downward into a more vertical orientation. The RB22's looks to be a more gradual, simple shape--a ramp, not a scoop. A major difference there is that the airflow vector through the FLEDs is different, with Audi's receiving a more perpendicular airflow onto their FLEDS, while RB22's you have to assume has an airflow approach angle more like 45* or less.
venkyhere
43
Re: Red Bull RB22
vorticism wrote:
16 Feb 2026, 16:35
vorticism wrote:
04 Feb 2026, 18:38
Confirmed:
Nice...
Just so I am grasping your post, is this what you mean ?
If possible, also include the bottom SIS in your diagrams, so that it can help us even more with understanding.
venkyhere
43
Re: Red Bull RB22
Owen.C93 wrote:
16 Feb 2026, 16:28
https://i.ibb.co/4Z5CZkzV/c-copy.jpg
Looks like a fore-hinged swing arm (with vertical 'play limiter' towers on either side) of some sort that is weight-bearing.. One of the engine/gearbox mounts ?
SiLo
144
Re: Red Bull RB22
Could they not run an undercut still from the Y axis where this floor extension meets the sidepod? Really it seems like as long as the front of the sidepod meets the X, Y, Z criteria for curvature, they could transition into a normal one quite easily?
Felipe Baby!
