Mclaren Mercedes MP4-25
Holm86
255
Re: Mclaren Mercedes MP4/25
Didnt see if it was jensons og hamiltons car but it definitely looked like they are blowing both elements on at least one of the cars.
lotus7
lotus7
zgred wrote: Image
Looking at the few threads on the hub to locate the lug nut , I wondered what happened to the old MSA regs that required the lug nuts to locate on the bolt /stud etc at least 1 1/2 times the bolt/ stud dia . i.e 12mm bolts/studs should locate 18mm into the nut.
240
Button has nothing to lose, so i think he can gamble on the parts.
Hopes it doesn't detract from meaningful testing in practice.
Any shots of new parts?
gibells
gibells
A picture in F1.com gallery shows Hamilton still using the F Duct blowing the main plane, not the upper plane.
imightbewrong
imightbewrong
Looks like button tried both types:
come one guys, more pictures!
murtoidf1
murtoidf1
didnt they say the rear wing was called the rw80, when the bbc asked what the name for the f duct was?
so whats this wing then..
Sean H
Sean H
RW (rear wing) 80 (80th design/update etc)
notice RW75 in background.
"The car is slow in the straights and doesn't work well in the corners." JV
MikeFromCanada
feynman
feynman
Sean H wrote:RW (rear wing) 80 (80th design/update etc)
I thought the number was a reference to the downforce. Engineer to mechanic, "we are gonna change the rear wing, take off the 80 and get a number 75 out of the truck, please".
Or in this case, get a 75 of the old wing ...
Rear wings aren't much adjustable anymore, they all come into the garage preset at their respective levels and angles.
murtoidf1
murtoidf1
lol yes i noticed it said rw75 in the background.. bt like i said i thought it was called the rw80, so is this an older wing or what?
It would make more sense if it was downforce. interesting.
forty-two
I'm pretty sure I heard a McLaren employee (Whitmarsh, or maybe Button) during an interview joking that everyone outside the team called it an F-Duct, but they called it RW## for rear wing iteration ##.
esbjornzon
esbjornzon
Just heard from the Swedish broadcasters that Button is trying out a new electronical brakebalance adjuster that isn't really working that well. Any more info on this?
zgred
autogyro
autogyro
esbjornzon wrote:Just heard from the Swedish broadcasters that Button is trying out a new electronical brakebalance adjuster that isn't really working that well. Any more info on this?
Sounds a bit like grasping at straws with the weight distribution and tyre balance problems.
