basti313 wrote:
WRONG
: In 1999 Luca Baldiserri was Irvine's race engineer and the pit crew stayed the same.And actually it was Luca Baldiserri with whom Schumacher won the title in 2000...so no Nr. 2 engineer...
That he was
promoted to be MSC's engineer tells you he was very good.
I wouldn't say my assessment is wrong senhor Basti. Just different to your own, as my point didn't say Irvine had to change engineers.
He had more access within the team, as he was now the spearhead....do you not concur? Sharing is caring after all.
basti313 wrote:Also WRONG: There were rumors that Ross Brawn and Luca Baldiserri had their issues with trading data within the team. Both pit crews and race engineers were rather working on their own, with or without Schumacher. Irvine profited from nothing.
Again, I wouldn't go as far as suggesting WRONG. You are basing your opinion on a rumour, Monsieur Basti.
I'm basing mine on Jean Todt and Ross Brawn getting the job done and making sure a WDC title tilt works.
If Brawn had an issue with Baldiserri, Baldiserri will be yielding quicker than a scolded cat. Brawn had rank after all.
basti313 wrote:Newey also mentioned, that driver feedback does not play a role in his car development.
Newey said no such thing.
Q: So it was never a Mansell, Prost or now Vettel car, but rather a Newey car…
AN: Well, what does happen is that when we have continuity in drivers like we’ve had for the last few years with Sebastian and Mark (Webber) then you listen to their feedback and the car evolves at least in parts as a result of their feedback. That does happen.
http://www.formula1.com/news/interviews ... 15315.html
Anyhow this is all sidetracking from the initial point that a number 2 driver elevated to number 1 status will perform better in terms of results.
And how this relates to Vettel and Ricciardo, is that at some point Red bull will have to make a choice based on which feedback will give them the greater chance of success.
It is clear Vettel is hurting from lack of EBD and or/rear DF.
If Red Bull cannot replicate this sort of DF quickly, Ricciardo will have a greater say in how things move forward as he is dealing with the issue better than Vettel.
Which is also why I'm intrigued as to how this sort of DF can be replicated. Because I don't think it can, unless you place a barn door rear wing and suffer down the straights, which is not going to happen at Red bull.
