Ferrari SF23
CaribouBread
CaribouBread
101
Re: Ferrari SF23
23 Feb 2023, 13:56
My uneducated guess is that bit of the bodywork has a different finish/wrap/polish that is making the flowviz look brighter/denser. Its almost a perfect square bit of bodywork where it looks brighter.
101FlyingDutchman
101FlyingDutchman
Re: Ferrari SF23
23 Feb 2023, 13:56
Almost like the lowest pressure is on the outside of the skin and it’s literally diverting the flow vis that has gone inside the pod through the seem of the panels
Re: Ferrari SF23
I suspect that's a fibreglass panel for signal transparency to the transponders and aeriels and just either has a different surface finish as a result or simply didn't get coated with the sealants they use over the rest of the car.
Re: Ferrari SF23
Good look at floor edge design.
Xyz22
Xyz22
125
Re: Ferrari SF23
Giando
93
Re: Ferrari SF23
Oh, finally a shot which shows the complex shape of the lower part of the chassis and suspension...
Yellow main edge / Cyan additional edge
Re: Ferrari SF23
tpe
tpe
-4
Re: Ferrari SF23
Giando wrote:
23 Feb 2023, 12:35
soooo, I was on spot since day one apparently... :mrgreen:
Twin Keels, Single Keels, Triangle keels.
I don't recall any good twin keel car though...
sunny1304r
sunny1304r
Re: Ferrari SF23
Have you seen a dimple on ferrari's nose at the end of the straight ? is it real or just light playing a trick ?
CaribouBread
CaribouBread
101
Re: Ferrari SF23
sunny1304r wrote:
23 Feb 2023, 18:20
Its real, the nose fascia was deforming on straights because it wasn't reinforced enough. Its unintentional and they've said they'll remedy it. I think its already fixed for the evening session. If not it'll be fixed overnight.
101FlyingDutchman
101FlyingDutchman
Re: Ferrari SF23
sunny1304r wrote:
23 Feb 2023, 18:20
Been reported. Is a simple of the panel there caving in under high load. Will get fixed. Panel bends back at lower speeds
sbrillo
sbrillo
Re: Ferrari SF23
do you notice that at the end of the session, Ferrari mount support on the FW? On both sides, from the higher part of the nose almost to the endplates. Do they want verify rigidity of the FW?
GrrG
86
Re: Ferrari SF23
gordonthegun
254
Re: Ferrari SF23
New point of view:
sbrillo
sbrillo
Re: Ferrari SF23
According to Franco Nugnes, today Ferrari was just search the correct balance of the car, exploring various heights from the ground to see when porpoising appear.
