Sergej wrote: ↑26 May 2025, 11:40
Space-heat wrote: ↑26 May 2025, 11:26
organic wrote: ↑26 May 2025, 09:36
We just have to hope Barcelona is cold
Slightly out of the loop. RB brought their McL-esque rear tyre solution to Imola. Is there another iteration expected in Austria, or what does the rear corner upgrade refer to?
yes, we have info from commentators speaking with Lambiase, who told them that they are doing an extensive work around the rear corner, which will be concluded in one month, this was said last week so I think around Canada/Austria
Thanks, does the rear corner refer to flow conditioning winglets, revised internal brake ducting, or is it related to the floor, or all of the above? Was there any indication, or was GP potentially discussing the Imola rear tyre update when he mentioned it?
It is interesting if it is still the brake ducting/rear tyre internal flow distribution. I thought Marko communicated that RB were matching McL on the rear tyre wear post Imola. Continued development would suggest the McL solution is a little more nuanced if RB feel there is still a chunk of performance to find.
Looking forward to Spain to finally put to bed this McL-RB-Merc-FER flexible front wing debate (who benefits most etc.). Knowing F1, one of the above will circumvent and kick off more drama.
