Ferrari F2012 (pre-launch speculation)
Forza
238
Re: Ferrari F2012 (pre-launch speculation)
"AUTOSPORT understands that Ferr is working on the front fDuct concept tried by Merc which redirects the airflow to cut drag at high speed"
Interesting where the deveoplemnt goes if true they will put combination of RRH and front F-duct toghether on front end of the car. The reports now suggesting that they work on both systems.
King Six
King Six
I'm surprised the FIA hasn't banned all of this yet. I'm sure they will for 2013, if somehow they don't (highly unlikely) then I'm 100% it will be with the new 2014 rules.
amouzouris
105
With the new way scarbs illustrated the noses will be this year..would the f10 nose be legal??
aleks_ader
90
amouzouris wrote:With the new way scarbs illustrated the noses will be this year..would the f10 nose be legal??
NO
amouzouris
105
i mean with a bit of fiddling around with the height of the nose cone ahead of the front bulk head reducing it at 550mm the rules say this year...would it then be legal??
MIKEY_!
Lets use this as a guide for what noses would be legal.
Thanks to scarbs yet again.
italian
italian
Have you seen The Flying lap this evening?
Read here: http://www.boxgp.com/formula-1/item/161 ... Ms.twitter
"Two things are infinite: the universe and human stupidity, but about the universe I still have some doubts." Albert Einstein
Pandamasque
I'm confused. After reading scarbs' blog I thought FIA lowered the maximum height of the bulkhead and not the nosecone (hence the 'upturned' nose on the scetch). Other sources suggest the opposite: 2011 bulkhead hight is still legal, but the nosecones must be lowered.
beelsebob
beelsebob
85
Pandamasque wrote:I'm confused. After reading scarbs' blog I thought FIA lowered the maximum height of the bulkhead and not the nosecone (hence the 'upturned' nose on the scetch). Other sources suggest the opposite: 2011 bulkhead hight is still legal, but the nosecones must be lowered.
This is the new rule:
F1 Technical Regulations 2012 wrote:3.7.9 No bodywork situated more than 1950mm forward of rear face of the cockpit entry template may be more than 550mm above the reference plane.
MIKEY_!
Sorry, this sketch is more recent and accurate.
Pandamasque
Thanks! Still ugly though #-o
Ra8
Ra8
MIKEY_!
All hail the front wing F-duct!
232
MIKEY_! wrote:Sorry, this sketch is more recent and accurate.
The 550mm height has to be at the end of the tub, section AA.
This drawing needs to be adjusted.
some possibilities:
beelsebob
beelsebob
85
ringo wrote:The 550mm height has to be at the end of the tub, section AA.
No, as I've said repeatedly, this is a common misunderstanding based on early reports of the rules. The exact rule is:
This point is forward of the front bulkhead, not the front bulkhead.
