Red Bull exceed fuel flow limit, Ricciardo DSQ at Australian GP
hardingfv32
hardingfv32
Re: 2014 Australian Grand Prix - Melbourne
Ral wrote:It really isn't that hard.
No it is not.... Fuel rate measured using injector data vs a FIA flow meter that must be re-calibrated during the race. Any doubt about which is more accurate?
Brian
jz11
jz11
19
on top of that, the flow meter is apparently calibrated against that very same injector data... so go figure
Tim.Wright
330
I think I'm going to stop pushing the point because its going nowhere.
But Ral, what you have posted just confirms what I have been saying. The teams need to abide by the code, the sporting regs and the technical regs. This just tells me that the technical directives (which RB violated) are NOT the binding power here, the regs are.
The TD is not just another heading, its a completely seperate document that doesn't (as I understand) have any legislative power.
LionKing
LionKing
Technical Regulations copied from previous posts:
5.1.4 Fuel mass flow must not exceed 100kg/h.
5.10.3 Homologated sensors must be fitted which directly measure the pressure, the temperature and the flow of the fuel supplied to the injectors, these signals must be supplied to the FIA data logger.
5.10.4 Only one homologated FIA fuel flow sensor may be fitted to the car which must be placed wholly within the fuel tank.
Why people keep saying RBR did not use FIA supplied fuel meter? That part I don't understand.
As far as I know they did use it. It was in the car and obviously sending the values out. So RBR is compliant with 5.10.3 and 5.10.4.
The only issue is whether they adhere to 5.1.4 regulating the mass flow or not? If they can prove that they should win the appeal.
iotar__
This is the stage of dissecting technicalities of putting together written rules, application of the rules and long practical reality of application of the rules that becomes the standard and in fact a law (if not in contradiction with written rules). Law understood here as social agreement of F1 community.
So in reality FIA's delegates (their roles and responsibilities included in written rules) decide that practical application of the rules of fuel flow require certain sensor/offset, this is the basis of measuring fuel flow on every car uniformly, it's also done for a reason - inaccurate results from practice sessions. [Clarification of the rules because of changeable environment] One team refuses to comply and presents their own offset and results (I assume incomparable with others) thus breaking the law of F1 community. Trust me, I'm a lawyer. On the internet.
Meanwhile in alternative universe:
"F1 racing’s new era debuted in glorious fashion in Melbourne on Sunday, with its teams and drivers serving up a master class on how to combine cutting-edge hybrid technology with superb sporting spectacle."
Where are sector times in live timing you high-tech cutting-edge con-men?
dans79
267
Brian
for the last time man the the sensor didn't need recalibrated, RBR was told to correct the amount of fuel the where using because the sensor said they where using to much. RBR only really has two ways of doing that during a race, tell the driver not to use full throttle or adjust the map so that at full throttle less fuel is used. I would love to hear the radio message to Ric, "Ric only push the pedal 98% of the way down so we don't use to much fuel" :wtf:
202 105 104 9 9 7
GrandAxe
GrandAxe
LionKing wrote:Technical Regulations copied from previous posts:
Red Bull used their own fuel rate model and abandoned the FIA's. Its a software matter; in lay terms, the charge is that Red Bull effectively chucked out the FIA's directions about how code could read fuel parameters from the sensor and invented their own methods.
Skippon
Skippon
Re: Red Bull exceed fuel flow limit, Ricciardo DSQ at Austra
Yes - and it was to stop the teams doing their own thing regarding the software calculation of fuel rate that the FiA mandated their own fuel flow meter and it was to be the FIA sensor not the team that determined the legal fuel flow rate limit.
Which RB effectively refused to agree to use during the race.
beelsebob
beelsebob
85
jz11 wrote:why are you nit-picking? no one is concerned as to what happens inside the thing - the output is the mass flow, therefore you can ignore the detailed specifics and just say - it measures mass flow
I'm not nit picking. This is an important distinction. You guys claimed that there were no "flow meters" in the engine injectors because they're simply measuring time open, pressure etc, and then computing flow from that. Similarly, the FIA official flow meter is simply measuring velocity, temperature etc, and then computing flow from that. The two are doing the exact same job, in the exact same way. There is no reason to believe that the injectors do it more accurately than the FIA's sensor.
djos
113
The FFM uses an ultrasonic measuring device, this is in no way the same as calculating the fuel flow using pump pressure and injector open times!
Ultrasonic measurement is a last resort, it's horribly low res and why ultrasonic tape measures went the way of the dodo as soon and laser tape measures became affordable!
You only use ultrasonic measuring when you have no other choice.
"In downforce we trust"
dans79
267
djos wrote: The FFM uses an ultrasonic measuring device, this is in no way the same as calculating the fuel flow using pump pressure and injector open times!
None of these circular arguments mater. The sensor is what's supposed to be used to measure fuel flow, if they don't want to use the sensor, then they can feel free to pack up and go home.
202 105 104 9 9 7
djos
113
Thats a crazy argument! F1 is supposed to be about cutting edge racing, using unreliable and inaccurate FFM's is tarnishing F1's reputation!
They'd have been better of issuing titanium flow restriction tubes and then there's be no need to have this discussion!
dans79
267
djos wrote:Thats a crazy argument! F1 is supposed to be about cutting edge racing, using unreliable and inaccurate FFM's is tarnishing F1's reputation!
They are accurate, error is less than 1%, and from I have read over the last several months they are more accurate than the method RBR used. hence the reason the method RBR used is the fall back method and not the primary method.
202 105 104 9 9 7
R_Redding
R_Redding
dans79 wrote:They are accurate, error is less than 1%
That is to comply with the Tech Regs and the procurement contract..
http://www.fia.com/sites/default/files/ ... eter_0.pdf
Gill Sensors themselves quote" that 52 per cent of its meters are with a 0.1 per cent accuracy reading, with 92 per cent within 0.25 per cent".
After being calibrated by Gill Sensors ...they are then re-calibrated by Calibra Technology.
http://www.calibratechnology.com/
Calibra Technology will also help the FIA enforce the new rules by providing random checks of flow meters throughout the season.
Rob
Klaus
Klaus
Someone can correct me if I'm wrong, but I'm pretty sure that a flow restrictor will only limit the volume of fuel not the mass. So if you pressurise the fuel more (in order to compress the fuel) then you could break 100kg/h without triggering any volume limits.
This would explain the choice of sensor, as presumably it can measure both volume and density, allowing you to calculate the mass flow.
This tech may be slightly too immature at the moment (again, I don't know, but after the weekend it appears that the accuracy is there, it's just not consistent but F1 is meant to be about pushing tech to it's limit, then making it work. And if they find a way of making these sensors accurate then F1 will have done just that.
I think what says the most is that all the other teams seemed capable of dealing with this within the rules, while RB pushed things (as usual). This time though I think they picked the wrong fight in the wrong way.
