Mercedes W11
OO7
OO7
171
Re: Mercedes W11
Diesel wrote:
20 Feb 2020, 11:15
OO7 wrote:
20 Feb 2020, 02:45
It's difficult to see how airflow close to the wheel in this region is clean up compared to the area close the crash structure which is far more open as this McLaren image demonstrates:
https://www.racecar-engineering.com/wp- ... ca0012.jpg
I literally just posted this on the previous page :wtf:
And I reposted it?
NtsParadize
NtsParadize
Re: Mercedes W11
10.2.2 Any powered device which is capable of altering the configuration or affecting the performance of any part of any suspension system is forbidden.
Unc1eM0nty
Re: Mercedes W11
The more I watch the footage the more cleaver and simple the design seems, you have to admire the natural way it operates, I bet they don’t even have to think about it.
As they break into a corner their weight goes forward, as they brace against the steering wheel this is forced forwards, then as they accelerate pressure is released and the wheel springs back.
geraldix
geraldix
Re: Mercedes W11
I can't understand all this fuss about DAS legality...
It's pretty OBVIOUS Mercedes that has just spent a bunch of months, human resources and millions of dollars developing, building and testing a system that's completely ILLEGAL. Maybe for fun, maybe because they are just ignorant. After all, what do they know about building an F1 car? :roll: /s
Holm86
250
Re: Mercedes W11
Mercedes’ James Allison says the team are confident that their new DAS steering system on the W11 is fully legal, and the FIA are aware of it.
https://formulaspy.com/f1/mercedes-conf ... lity-67941
SiLo
139
Re: Mercedes W11
To put it it in the simplest terms possible (and why it's legal IMO):
When you turn the steering wheel radially, the toe changes, both front wheels are affected but are inversely related (toe increases one side and decreases the other side).
All Mercedes have done is add a longitudinal movement that changes exactly the same thing, except this time it is directly related (toe increase or decreases the same relative to each other on each side).
That's it. They have simply added another axis for steering.
Personally I think it's genius and will be copied by other teams quite quickly. Whilst it may sounds complex, they will figure out their own version rapidly, the real issue will likely be packaging, rather than how it actually works.
Felipe Baby!
bauc
Re: Mercedes W11
geraldix wrote:
20 Feb 2020, 15:30
The ''problem'' here is the different understanding/interpretation of the wording of the rules .... so it opens door for people to question some parts legality due to the same reason. I can assure you that there will be people who will put a legit argument why this is not legal and vice versa.
Re: Mercedes W11
AMG.Tzan
44
Re: Mercedes W11
jh199 wrote:
20 Feb 2020, 14:06
AMG.Tzan wrote:
20 Feb 2020, 14:01
Where did we get the information that it changes the toe angle??
You can see the angle change as Hamilton pushes and pulls the steering wheel. There were videos a few pages back but here's another video showing it.
Nice thanks...didn't watch carefully!
yelistener
Re: Mercedes W11
Am I just not familar with the words or what? Pushing the steering wheel creates "negative toe in, or toe out", right? That you see less area of the inner side of the tyres.
101FlyingDutchman
101FlyingDutchman
Re: Mercedes W11
It MAY get copied quickly but it depends whether the nose section will need to undergo another crash test as it’s part of the structural box
Holm86
250
Re: Mercedes W11
SiLo wrote:
20 Feb 2020, 15:33
All Mercedes have done is add a lateral movement that changes exactly the same thing, except this time it is directly related (toe increase or decreases the same relative to each other on each side).
Totally agree, theres nothing in the regulations that says the steering wheel cant move laterally, and wheel geometry can only be changed by imput from the steering wheel, which this does
Re: Mercedes W11
So both Allison and Hamilton said the FIA is ok with it. Interesting indeed. Teams can still protest of course.
Holm86
250
Re: Mercedes W11
turbof1 wrote:
20 Feb 2020, 15:42
ofc, but I doubt they can find any good argument why this is illegal.
Nothing says the wheels should rotate the same way when the steering wheel is moved
Re: Mercedes W11
It's easy to copy, but far more difficult for another team to implement because packaging in that area is trick to start with given the pedal box/steering rack/dampers/rockers/reservours, etc, all in there.
