In the race yes but it will shift things towards the McLaren's in qualifying. And passing in Silverstone when the car in front is just as quick is kinda tricky.
The RB21 doesn't have the best aero efficiency, it's quite draggy with the wing closed. Besides, the drag difference because of front flexing will be negligible, especially when the effect is felt across all teams.pantherxxx wrote: ↑30 May 2025, 13:24I think the new Td on flexi wings will help Red Bull massively. Because Rb21 still have the best aero efficiency in terms of drag. While Mclaren's car is already too draggy, and they had low top speed in Imola for example because of that. So because reducing flexing in the wings will massively increase drag, the already too draggy cars will suffer the most.
But the magnitude of that effect will vary greatly.Cs98 wrote: ↑30 May 2025, 13:28The RB21 doesn't have the best aero efficiency, it's quite draggy with the wing closed. Besides, the drag difference because of front flexing will be negligible, especially when the effect is felt across all teams.pantherxxx wrote: ↑30 May 2025, 13:24I think the new Td on flexi wings will help Red Bull massively. Because Rb21 still have the best aero efficiency in terms of drag. While Mclaren's car is already too draggy, and they had low top speed in Imola for example because of that. So because reducing flexing in the wings will massively increase drag, the already too draggy cars will suffer the most.
Mclaren's top speed was terrible in Imola (321 km/h), while Red Bull's top speed was exceptional (331 km/h). And even early testing data indicated the same.Cs98 wrote: ↑30 May 2025, 13:28The RB21 doesn't have the best aero efficiency, it's quite draggy with the wing closed. Besides, the drag difference because of front flexing will be negligible, especially when the effect is felt across all teams.pantherxxx wrote: ↑30 May 2025, 13:24I think the new Td on flexi wings will help Red Bull massively. Because Rb21 still have the best aero efficiency in terms of drag. While Mclaren's car is already too draggy, and they had low top speed in Imola for example because of that. So because reducing flexing in the wings will massively increase drag, the already too draggy cars will suffer the most.
Those numbers are not accurate and I'm not talking about with DRS open anyways. With the wing closed the RB isn't low drag at all. Like many false preconceptions this is a remnant of previous seasons when the RB was fairly low drag. Not the case anymore.pantherxxx wrote: ↑30 May 2025, 14:44Mclaren's top speed was terrible in Imola (321 km/h), while Red Bull's top speed was exceptional (331 km/h). And even early testing data indicated the same.Cs98 wrote: ↑30 May 2025, 13:28The RB21 doesn't have the best aero efficiency, it's quite draggy with the wing closed. Besides, the drag difference because of front flexing will be negligible, especially when the effect is felt across all teams.pantherxxx wrote: ↑30 May 2025, 13:24I think the new Td on flexi wings will help Red Bull massively. Because Rb21 still have the best aero efficiency in terms of drag. While Mclaren's car is already too draggy, and they had low top speed in Imola for example because of that. So because reducing flexing in the wings will massively increase drag, the already too draggy cars will suffer the most.
Mclaren's bendy walkover is over. Red bull for pole.euv2 wrote: ↑30 May 2025, 14:59https://postimg.cc/4Ybcbk0g
Comparing the two laps between NOR and VER it was very close in most corners besides turn 4 where Max loses a whopping 0.25 and another tenth at turn 12, the rest of the lap was pretty even with Max lifting throttle slightly less in the high speed.
Even engine modes look to be very similar, with almost matching top speeds and acceleration curves.
I think everyone basically has more or less same drag upto bendy rear-wings. Red Bull are being too stupid this regulation set by leaving free lap-time on the table.Cs98 wrote: ↑30 May 2025, 14:51Those numbers are not accurate and I'm not talking about with DRS open anyways. With the wing closed the RB isn't low drag at all. Like many false preconceptions this is a remnant of previous seasons when the RB was fairly low drag. Not the case anymore.pantherxxx wrote: ↑30 May 2025, 14:44Mclaren's top speed was terrible in Imola (321 km/h), while Red Bull's top speed was exceptional (331 km/h). And even early testing data indicated the same.
I think they are running more fuel. See the high speed losses. That's purely fuel. Engine modes seem similar. Ferrari/Red Bull are running less fuel.organic wrote: ↑30 May 2025, 14:32Norris' long run at the end of FP1 was bad, just looking at the laptimes. started in the low 1.20s and was doing high 1.20s towards the end. Leclerc just about stayed in the 1.19s. Max was driving to a 1.19.5 delta but had fresher tyres than the other two
Even if it comes up that McLaren were dropping engine mode (when have they been doing that this year?) they still had lots of deg on that soft run. Must be hiding pace unless they've completely got the setup wrong
