2025 McLaren F1 Team
FittingMechanics
FittingMechanics
16
Re: 2025 McLaren F1 Team
Macklaren wrote:
31 May 2025, 14:05
7 tenths is quite a big gap to be explained by engine modes
It's the temperature, like in Jeddah. But here we won't be racing and qualifying at night.
avantman
avantman
FittingMechanics wrote:
31 May 2025, 14:08
Macklaren wrote:
31 May 2025, 14:05
yes, 47 degrees during push lap attempts, the hottest we've seen all year even beating FP3 in Jeddah. some of it has to be power difference though.
BMMR61
Emag wrote:
31 May 2025, 13:38
31 May 2025, 13:36
Lando was on new softs when he made the mistake. I checked the onboard.
Insane pace regardless.
Maybe misstimed photo then. But yeah, Lando needs to put it together for quali then. Because 2 tenths off Oscar in S1 isn't going to cut it.
Planet F1 report - https://www.planetf1.com/news/spanish-g ... fp3-report
Meanwhile, his team-mate Piastri did a particular slow out-lap, almost crawling around the circuit. And then went purple, purple, and purple. A 1:12.913.
Makes sense because even with almost a lap of push prior to Lando going out again, 0.526 is a big gap. With 1.0 second up on Max, Red Bull have some work to do for qualifying this afternoon. I guess we've seen that movie before.....
BMMR61
avantman wrote:
31 May 2025, 14:13
31 May 2025, 14:08
Macklaren wrote:
31 May 2025, 14:05
That efficient McLaren cooling working to best effect. Are we going to see some more M-B PU failures here?
Macklaren
Macklaren
Anthony Davidson saying on Sky commentary that there is minimum 5 tenths difference between used Soft and new Soft, which explains Lando's gap to Oscar. Doesn't explain Lando's yellow first sector on his first run though but that may just be a mistake
avantman
avantman
BMMR61 wrote:
31 May 2025, 14:16
avantman wrote:
31 May 2025, 14:13
31 May 2025, 14:08
Was it reported Merc pu failures we saw in Monaco were related to overheating?
Macklaren
Macklaren
avantman wrote:
31 May 2025, 14:20
BMMR61 wrote:
31 May 2025, 14:16
avantman wrote:
31 May 2025, 14:13
ALO was a spark plug failure
mwillems
46
Certainly the rear has had some moments whilst finding the right balance, but otherwise this looks very good.
FP3 is generally closer in terms of the final gaps so... I'll stop there and not jinx it.
-Bandit
mwillems
46
BMMR61 wrote:
31 May 2025, 14:14
Emag wrote:
31 May 2025, 13:38
31 May 2025, 13:36
Ive not seen Max pull this gap in fp3.
I e pect them to close up a little, but my feeling is that this will be Miami lite.
The onus is on the drivers to not mess up.
Here's a thought... what if this TD benefits the car that has the most mechanical grip....
-Bandit
Emag
Emag
mwillems wrote:
31 May 2025, 14:34
BMMR61 wrote:
31 May 2025, 14:14
Emag wrote:
31 May 2025, 13:38
I dont think this TD benefits McLaren. They would have just had the stiffer wing to start the season if that was the case.
I do however believe its effects on overall performance were vastly overestimated since last year. So far, I am being proven right, however not a single representative session has gone by yet, so I could still be eating my words after quali and the race.
Plus, we would have to wait a couple of races to fully confirm the effects (or the lack of) the TD has had.
Developer of F1InsightsHub
Cs98
Cs98
The TD is a big nothing. Or at least compared to the effect that temperature seems to have on McLaren vs the rest.
mwillems
46
Emag wrote:
31 May 2025, 14:44
mwillems wrote:
31 May 2025, 14:34
BMMR61 wrote:
31 May 2025, 14:14
It's about who's better without the wing, undoubtedly everyone lost some benefit, but if the mechanical and aero baselines of one car is higher, and everyone's aeros baseline is slightly reduced by the same amount (for example), then couldn't the car with the bigger advantage to start then have a bigger relative advantage? There are always caveats of course.
Agree that we'll have to wait and see for several races.
But all I will put my name to for anyone who's been fixated on how the TD might retard a teams relative performance. It might do the opposite.
-Bandit
Mansell89
Mansell89
Did I see Oscar was 3 tenths up on the straights versus Lando over the lap in FP3?
Is that an engine setting thing or a set up issue?
FittingMechanics
FittingMechanics
16
avantman wrote:
31 May 2025, 14:13
31 May 2025, 14:08
Macklaren wrote:
31 May 2025, 14:05
Current track temp - 49C.
avantman
avantman
31 May 2025, 15:46
avantman wrote:
31 May 2025, 14:13
31 May 2025, 14:08
will certainly be lower in an hour when it matters.
