2026 Aston Martin Aramco Formula One Team
Ashwinv16
Re: 2026 Aston Martin Aramco Formula One Team
From Fp1 the biggest issue seems to be understeer on corner entry.
Halo not as bad as we thought
TyreSlip
TyreSlip
Ashwinv16 wrote:
01 May 2026, 21:12
Makes sense. There was talk that this car lacked a strong front end.
etusch
131
bigblue wrote:
01 May 2026, 20:33
I'm sure you're aware, the Hondas of the last few years have always sounded aggressive (sounds better than saying rough! - honestly I do think they've sounded good and somewhat characterful given the constraints of the current rules). Maybe he was running a different mode, or energy recovery strategy. Or maybe yes, just some mic difference. I guess we'll find out about vibration status at the end of the day once the team comments are out.
It's worth noting that Aston engineers have been over in Japan (seemingly through ther break if I interpret reports properly, at the very least they've been in close collaboration), along with a car, so it's not as though Honda were doing this on their own, though the PU-side obviously is predominantly in their hands.
Also Orihara said, “We have made some progress, allowing us to implement further countermeasures in Miami and later in the season", so there's seemingly more to come if this is to be taken as an accurate quote (I'd speculate that means with an ADUO upgraded engine, but who knows).
Although there are no chassis aero upgrades declared, I suppose that leaves the possibility that some weight reduction occurred, but so far I haven't seen anything reported to that effect.
Edit: typed out in response to GoranF1, and then the couple of posts above arrived whilst I was doing so, thanks for the info!
Introducing chassis upgrade at sprint weekend is not so good and + only pu improvements to see real affectiveness of them
Rikrikrik
Rikrikrik
After all things, its positive. Its not worse than Melbourne. It is already a step forward. Seems a "normal" team, but slow.
GoranF1
GoranF1
149
Ashwinv16 wrote:
01 May 2026, 21:12
Also big problems on rear traction out of last corner.
V10FURY
V10FURY
Stroll out after huge lock up
Alonso bailed on his fast lap. Not good… #-o
On the other hand Perez in the
Cadillac looks improved this weekend for sure, only 3 tenths away from 14th and 1 second away from 9th! That’s a huge step for that team and shows some great momentum. Aston needs to get its act together here as it is starting to become a serious embarrassment.
SSJ4
SSJ4
32
V10FURY wrote:
01 May 2026, 22:51
active aero failed for alonso. thats what caused the lockup
Rockypeeters
Rockypeeters
5 weeks and AM has somehow gotten slower.
SealTheRealDeal
SealTheRealDeal
Rockypeeters wrote:
01 May 2026, 23:50
That was expected given how the season started wasn't it? The other teams could focus on performance while Aston worked on making its car actually function.
bigblue
Aston F1's website is quite hard to navigate. Currently there are a couple of minimal quotes from the drivers here, just mentioning locking (both), and improvements to vibrations (Alonso) without much more.
Edit: actually Stroll said they both experienced locking, Alonso mentioned the vibration improvement and lack of pace.
mzso
mzso
76
The commentators claimed Alonso was massaging his wrists after FP... Doesn't sound like the vibrations are at a reasonable level.
Emag
Emag
137
I think people should accept this is a failed project for this season (at the very least). They're always going to undersell the severity of the issues, because nobody wants to come out and say "yes, we are horrible at our job".
It's what happened in 2015 as well. This time it's not for the same reasons, but rush certainly played a role in it. Honda should learn to just say no to some requests. A power unit that compromises the chassis but outputs acceptable power is 100 times better than whatever they ended up with this season.
There isn't much to salvage for this season, which is why they should just use it as a testing platform so that the 2nd iteration next year isn't as embarrassing.
Developer of F1InsightsHub
bigblue wrote:
02 May 2026, 00:33
ALONSO...
A tough Friday for the team here in Miami.
"Honda have made some improvements on the vibrations since the first few races, but we're still lacking pace.
"It's a process that will take time, and we need to stay patient. We'll look at the data tonight and try to make the most of the rest of the weekend."
zoroastar
stroll didnt make his final run because of vibrations. i couldnt understand whether it was caused by his off or it was ongoing through the run. it seems like its intermitent
HondaPOD
HondaPOD
zoroastar wrote:
02 May 2026, 04:15
Stroll was unable to complete his final lap because he braked so hard that he damaged his tire. He could have let it go into the run-off area and started another lap. He also impeded Alonso.
The vibrations are due to that.
