Red Bull RB22
Re: Red Bull RB22
venkyhere wrote:
18 Feb 2026, 10:50
Is this really an undercut, probably need a front-on image to confirm, but from this, it just looks like a more sculpted version of the same 'teardrop' thing
The undercut is in the front. The rear doesn't have an undercut.
Beware of T-Rex
Sieper
73
Re: Red Bull RB22
This is not just an undercut, they moved the cooling up higher, above the C from oracle there now is a bulge. They are comparing the two solutions. I think they will go to this more traditional "undercut" style. though the weight is higher up.
Re: Red Bull RB22
It looks like active aero was revised?
Beware of T-Rex
euv2
euv2
Re: Red Bull RB22
Re: Red Bull RB22
The new front wing didn't stay on for very long. It looks like it was only run with the aero rake. After the rakes were taken off, the flat front wing was put back on the car.
Beware of T-Rex
Re: Red Bull RB22
They've added a wiggle to the mirror stay.
A nice view of the SP undercut. It very much is a g-line undercut combined with a slimpod.
Compared with geometry from Barcelona/test 1 the difference is pretty stark.
The sidepod is a midway point between two extremes:
Mercedes - They have the standard height inlet, the g-line undercut (although moderate) and blend between in/downwash at the rear
Audi - at the front of the sidepod it overhangs the floor LE, pressurising the FLEDs, and the sidepod itself is narrow (exposed SIS)
Badger
Badger
46
Re: Red Bull RB22
Completely as expected. The sidepod never looked its final form in the first tests, and it was never expected that the undercut would be as extreme as the teams with wider pods.
Re: Red Bull RB22
As spotted by brakeboosted red bull also extends the crash structure winglet, but not to the extent of Ferrari today, but it is the second most extreme vertical extension of the diffuser on the grid
Cassius
Cassius
Re: Red Bull RB22
New shape of the more forward engine cooling outlet as well?
Re: Red Bull RB22
Cassius wrote:
18 Feb 2026, 14:28
Yeah. Probably why they tested a multitude of variants of that outlet at Barcelona
vorticism
vorticism
449
Re: Red Bull RB22
18 Feb 2026, 14:02
So does this reduce/eliminate the floor extension?
The transparent panel also looks to be gone.
venkyhere
43
Re: Red Bull RB22
18 Feb 2026, 14:23
https://i.ibb.co/4wYHqwrK/20260218-122244.jpg
Tighter engine cover as well. The big-hole main rear exit is the 'odd man out' amongst so many 'tight exit' cars on the grid. Like the odd guy with a beer belly in a special forces unit. :D
vorticism
vorticism
449
Re: Red Bull RB22
18 Feb 2026, 14:23
The height of the tailpipe relative to the CS is odd. The wing stays encapsulate the sides of that same area--so why haul around a void in that region? Maybe they'll also show up with an exhaust plate/ramp in that area. They have room to drop the tailpipe down--look at the height of its support.
ChrisM40
ChrisM40
Re: Red Bull RB22
vorticism wrote:
18 Feb 2026, 15:14
18 Feb 2026, 14:23
Isnt the exhaust position and length fixed by relative position to other components, in the regs? It may not be as simple as just moving it down.
euv2
euv2
Re: Red Bull RB22
