Mclaren MCL40
Re: Mclaren MCL40
https://www.motorsportmagazine.com/arti ... e-in-2026/
Mark Hughes says McLaren is a full 10cm shorter in terms of wheelbase than other cars
Macklaren
Macklaren
Re: Mclaren MCL40
25 Feb 2026, 22:23
That's pretty crazy? How is this car overweight in that case?
De Wet
Re: Mclaren MCL40
Macklaren wrote:
25 Feb 2026, 22:42
25 Feb 2026, 22:23
All the electrical nonsense with these regulations.
Re: Mclaren MCL40
Macklaren wrote:
25 Feb 2026, 22:42
It's just 10cm.
Beware of T-Rex
Re: Mclaren MCL40
Macklaren wrote:
25 Feb 2026, 22:42
25 Feb 2026, 22:23
By adding extra ballast to meet the mandatory weight distribution?
SilviuAgo
121
Re: Mclaren MCL40
Some teams do not have synchronized active aerodynamic flap openings. At the moment, based on our images, #McLaren, #Alpine and #Cadillac appear to use different flap opening timings. For the moment there are no significant advantages to this solution, since active aerodynamics can only be used on the straights and deactivate as soon as the driver begins braking. (Source AndreaGalante)
Re: Mclaren MCL40
SilviuAgo wrote:
26 Feb 2026, 17:37
https://pbs.twimg.com/media/HCAECHTXwAA ... name=large
relevant:
algebraist wrote:
27 Feb 2026, 02:11
Dusting off my old account ... to my inexpert eye, I think they've managed a real clever trick here.
2) The car has been observed lowering it's front wing a second or two after the rear wing flips.
3) The Williams FW14B had an early DRS button on it where the active suspension pitched the front of the car down, and the rear upward in order to stall the diffuser in a straight line and remove a significant amount of drag.
I suspect the Ferrari may be pulling the same trick: to effectively "parachute" the car and remove a ton of diffuser drag in a straight line. I've only got prior art and observed behaviour to go on however.
Beware of T-Rex
Stu
Re: Mclaren MCL40
I can see some logic to offsetting the flap operation.
For one it allows any destabilisation created to affect one end of the car at a time.
Secondly, the original intent was to not have zones for usage, but be limited by the attitude of the car (yaw).
Thirdly, being able operate the two ends separately would allow the front to be in the normal position and rear flaps in low drag mode for overtaking manoeuvres.
venkyhere
43
Re: Mclaren MCL40
Stu wrote:
27 Feb 2026, 08:58
It's not 'operated separately' right ? Just implemented separately, with actuation delay added to one end from a single button press that's commanding both ends. So it's not as if the driver can put one wing in low drag mode, and then time the other wing's operation in-situ with his overtaking maneuver. Or so is how I understand the rules regarding this, not sure whether there is a loophole that allows driver controlled separately timed action.
SilviuAgo
121
Re: Mclaren MCL40
Macklaren
Macklaren
Re: Mclaren MCL40
Wow not many (any?) cars are below the minimum weight right now?
johnnycesup
johnnycesup
Re: Mclaren MCL40
If he's talking about front/rear weight distribution, there's not a lot of room for change, the regulations lock the front axle at a 44-46% of the weight.
It's one of the most stupid parts of the rules IMO, what does that accomplish? Is it all because of Pirelli?
markc
Re: Mclaren MCL40
It's to try and stop a particular team from being lucky with weight distribution giving them an advantage because they land on the sweet spot, so mandated weight distribution removes this element.
Owen.C93
Owen.C93
189
Re: Mclaren MCL40
johnnycesup wrote:
27 Feb 2026, 20:10
Technically the weight distribution isn't fixed, only the minimum weight on each axle. So if you're 5kg over weight on the rear of the car then you will have a more rearward weight distribution.
(The plus side of that is you don't have to add a counterbalance to stay within the regulation)
So based on what he's saying, it sounds like it's one end of the car which is more overweight, which is causing them weight distribution issues as well. If I had to assume, I would say they're too heavy at the rear.
johnnycesup
johnnycesup
Re: Mclaren MCL40
Owen.C93 wrote:
27 Feb 2026, 21:13
Well spotted, I misread the regulations, thanks!
markc wrote:
27 Feb 2026, 20:49
As Owen.C93 explained (and I misunderstood), you can have weight dsitribution outside of that window, it just costs extra weight.
I disagree with your "lucky" weight distribution thing tho, teams should be able to adjust their own weight distribution to get a balance that better suits their own car. Is it not just as lucky if your car performs better in the prescribed (at the minimum weight) weight distribution?
