Mercedes W13
240
Re: Mercedes W13
The car hasn't seen much changes over the season. Nothing drastic.
However, if they do get a new nose, will it have a separated lower plane like the other cars?
prox
Re: Mercedes W13
Is that a high and low DF version of the same wing as the top planes differ?
georgekyr
georgekyr
Re: Mercedes W13
Maybe it is exactly the same and it is pespective since the upper one is almost at the same height as the camera while the lower one is angled in relation to the camera - check the top part of the end plate.
RZS10
359
Re: Mercedes W13
Relatively sure it's the very same wing elements they had throughout the season, here's Miami for example
F1Krof
95
Re: Mercedes W13
Looks more narrow to me.
Wroom wroom
Mchamilton
Mchamilton
Re: Mercedes W13
F1Krof wrote:
21 Jul 2022, 18:42
You are seeing things
prox
Re: Mercedes W13
georgekyr wrote:
21 Jul 2022, 18:11
No, the profile is distinctly different, the bottom image shows a smooth continuos edge where as the top image is more shaped almost angular in appearance.
Puffpirat
Puffpirat
Re: Mercedes W13
That’s definitely two different profiles. On one there is some black above the petronas logo, on the other there isn’t and as prox said one is wavy and the other a smooth curve.
pursue_one's
97
Re: Mercedes W13
Austria
Canada
Re: Mercedes W13
21 Jul 2022, 12:01
They didn’t even bother to list the front wing in the pre-event changes note, that’s how insignificant the changes are.
prox
Re: Mercedes W13
There were rumours of an engine fix, to allow them to run at full power. I think this was more optimistic speculation.
Re: Mercedes W13
prox wrote:
22 Jul 2022, 12:07
After the Summer break.
mafeotul
mafeotul
Re: Mercedes W13
214270 wrote:
22 Jul 2022, 12:08
prox wrote:
22 Jul 2022, 12:07
Has it been confirmed the PU hasn't been ran at full power? I don't remember seeing this.
Re: Mercedes W13
mafeotul wrote:
22 Jul 2022, 12:11
214270 wrote:
22 Jul 2022, 12:08
prox wrote:
22 Jul 2022, 12:07
https://www.formu1a.uno/mercedes-e-stat ... e-redbull/
The launch of the PU Phase 3 is expected after the summer break, which should also include the introduction of the new hybrid part and thus bring performance even closer to the more performing PU Honda and above all Ferrari, finally using the 2022 unit at full power. Until now, albeit with the second specification a step forward has been made, the use was conservative for reasons of reliability and consistency.
- Google Translated
atanatizante
129
Re: Mercedes W13
Pictures via Motorsport.com
Motorsport.com quote:
Mercedes, which will be running with a revised cooling duct on its nose that was spotted on Thursday, has also made changes to the floor edge and the front brake duct.
On the floor there is a reduced curvature on the edge ahead of the rear tyre.
The team explained that this: "reduces local floor load by reducing the local camber [thereby] improving flow into the diffuser, which is turn increased diffuser load."
The addition of internal louvres at the front brake duct exit are aimed at improving cooling, with very hot temperature expected in France this weekend.
Jesus
