djos
116
Re: A shameless thread for the enginephiles
Dragonfly wrote:And it's a Diesel one. They have a long tradition of building air cooled engines. Mounted on vehicles from heavy trucks to limousines.
Shush, you can't be telling folks I willingly posted a picture of a Diesel engine! I have a reputation to up hold!
"In downforce we trust"
xpensive
xpensive
214
Eyecandy, a quad-turbo jaguar V12!
Sombrero
Sombrero
126
The first series production V6 (60 degrees) was introduced by Lancia in 1950 with the Lancia Aurélia.
Best known as the designer of the world’s first production V6 engine, De Virgilio worked closely with Gianni Lancia, the company head, and Vittorio Jano, to produce the Lancia Aurelia.
http://lanciainfo.com/Lancia_Info/De_Virgilio_book.html
Cracking the V6 code wasn’t easy. A prototype V6 with 1569 cc at 45 degrees was built, and after a few more tries De Virgilio realized that an angle of 60 degrees would work best.
The narrow angle made it difficult to employ hemispherical combustion chambers, and the valves were placed 90 degrees from the normal position, resulting in a very unusual head design. (see diagram). As usual, to make things more interesting, Lancia historians refer to this design as the ’straight valve’ engine. Says Goldberg, “The valves were originally parallel to the axis of the crankshaft. That would be turned 90 deg from the intake/exhaust direction, but are termed the “straight valve” engines.” Valves at any angle were operated via pushrods from a single camshaft in the center of the block.
According to Geoffrey Goldberg, De Virgilio’s papers show the 60 deg V6 balancing drawing in 1943, and the 538 45 degree engine in 1944, with the first test engine being the 538 in 1945. “That engine, which one could describe as the start of things, was installed in an Aprilia in 1948, and driven around.” The 60 degree engine was likely built in 1949, as it was introduced in 1950.
Source : VELOCETODAY
http://www.velocetoday.com/lancia-aurel ... iation-pi/
http://www.velocetoday.com/the-lancia-a ... ation-pii/
NEW : sample pages of the book http://blog.lanciainfo.com/wp-content/u ... .20.14.pdf
bhall II
bhall II
477
djos
116
Wow, that is a very weird but clever concept - I wonder what durability is like having to seal a rotating combustion chamber?
Dragonfly
Dragonfly
It does not necessarily need to be rotating IMHO.
Spa 2012
FW17
171
FW17
171
FW17
171
Ferrari NHRA
FW17
171
Porsche 917 again
dren
228
Honda!
dren
228
Veyron W16 Quad Turbo (didn't see this posted yet?)
Honda!
dren
228
Le Rhône 9C 80hp WWI Engine
Oberursel U.III 160hp Engine
Honda!
Pierce89
Powerslide wrote:
flynfrog wrote:the LT5 was a corvette motor not buick. GMs rare dance with overhead cams.
http://www.zr1specialist.com/HAT%20Web/ ... P_0796.JPG
Designed by Aston Martin?
Actually it was built by Mercury Marine. Lotus just did the original drawings.
