Aston Martin AMR24
Re: Aston Martin AMR24
Flow-Vise in FP1
jrdls
jrdls
jjn9128
786
jrdls wrote:
25 May 2024, 04:27
Any signs of flow separation? I don't trust my judgement.
yep - but at Monaco that's not a disastrous thing, you can have a surprising amount of separation on a wing before it's at peak downforce. It's just quite draggy.
How I read it - and it'd be easier under a UV light - if you look at the wing you see a thin band on the flap where there doesn't look to be any flowvis - this is the transition bubble between laminar and turbulent flow regimes. Then the flowvis gets a bit speckly but still has striations - that's turbulent. Finally mid-way up the sponsor there's another thin band where the recirculation has settled the paint a bit then it's whispy and speckly but no longer has linear striations - also behind the centreline and the DRS actuator there's a V of loss.
#aerogandalf
Just love how close to the ground the car looks in this shot.
Leon
Leon
The diffuser photos by Xavier are for RB20, not AMR24
<thanks for the correction, deleting those posts>
"Clouds now and again
give a soul some respite from
moon-gazing-behold."
Matsuo Basho
The Silverstone team must get out of a conjuncture phase: the new package brought to Imola did not work compared to expectations. In Montreal the front wing with the V in the two upper flaps and a bottom that has been revised to correct the defects that emerged in Italy. Fallows looks for a balance that AMR24 lacks.
https://it.motorsport.com/f1/news/f1-as ... /10620194/
Compared to the original version, the one brought to Canada has the last element that has been revised in the slightly increased rope on the exit edge since the addition of a nolder that was not there in Italy. Although the Montreal track would require a medium-low load setup, in Aston Martin looking for that missing aerodynamic balance with a slightly more impactful solution.
-wkst-
-wkst-
Should be Jeddah-spec.
AMuS
Luscion
Luscion
154
new beam wing
quincalla
quincalla
New engine cover fin.
Ashwinv16
New Beam Wing and likely underfloor (beam wing now more surface area than the one in Monaco, but with more gradual of angle of attack(so less loaded)) (New rear wing hidden? (old wing in garrage)
Not sure if there are changer anywhere else
Halo not as bad as we thought
KimiRai
KimiRai
301
Ashwinv16 wrote:
20 Jun 2024, 22:33
https://pbs.twimg.com/media/GQgkl-CWwAA ... ame=medium
https://pbs.twimg.com/media/GQg5_z8X0AA ... ame=medium
https://pbs.twimg.com/media/GQgkksfW4AA ... ame=medium
https://pbs.twimg.com/media/GQgklR_XAAA ... ame=medium
https://pbs.twimg.com/media/GQgkj6iWMAI ... ame=medium
Rolling stones lips beam wing
