McLaren MCL39
venkyhere
45
Re: McLaren MCL39
SilviuAgo wrote:
29 May 2025, 17:59
bauc wrote:
28 May 2025, 14:11
Rikhart wrote:
28 May 2025, 10:49
By Gary Anderson :D
Whatever Gary says, its always the opposite to be true :D
Here his opinion on Front Wing topic. Maybe this time is right :lol:
https://www.the-race.com/formula-1/gary ... l-ferrari/
There are 'technical articles' all over F1 media, claiming diametrically opposite results w.r.t TD08:
A) McLaren to suffer least, Ferrari & Redbull to suffer most.
B) McLaren & Mercedes to suffer most, Redbull to a lesser extent and Ferrari the least to suffer.
I think the best thing to do will be to not get sucked into 'confirmation bias'/'echo chamber' conclusions and set expectations around it, and show patience only until Saturday Q, for the truth to show itself up.
Re: McLaren MCL39
Cs98
Cs98
Re: McLaren MCL39
the big shift happens at around 140-150 kmh where the new wing flexes a lot more
I presume you mean the opposite?
Like you say, the biggest difference seems to be in the 150-200 range. So medium-high speed corners.
Re: McLaren MCL39
Cs98 wrote:
30 May 2025, 12:34
yes, the old one starts flexing really quickly at medium speeds, probably even around 100 kmh
new wing is very stiff up to 150-160 and gradually (almost linearly) flexes further
SilviuAgo
184
Re: McLaren MCL39
Now on F1TV live stream Alex Brundell, presenting McLaren FW said that he spoke with Rob Marshall and the outcome is like this:
AB: What changes did you do to the FW?
RM: We added one hook to the top flap. No material changes on FW.
AB: So how you mitigate the loss?
RM: What loss?
Interesting. If no material changes were needed to stiffer the FW and only one hook was needed, then the impact should be reduced and new pecking order in F1 not to happen, as many expected staring with Spain.
FP1 on going now, MCl39 looking good.
Emag
Emag
137
Re: McLaren MCL39
SilviuAgo wrote:
30 May 2025, 13:55
RM: What loss?
I’ve always thought the primary benefit of a flexi-wing is drag reduction. You can run with a big front wing to get the downforce in medium and low speed corners without sacrificing top speed. You could still do the same thing now, with a bigger drag penalty.
The claims about flexi-wings being some sort of balancing tool seemed a stretch, but I am not an aerodynamicist, so I took expert’s word for it.
I just dont think there is enough control in a naturally flexing front wing for it to effectively be used as a corner-to-corner balancing tool.
Developer of F1InsightsHub
CjC
CjC
Re: McLaren MCL39
SilviuAgo wrote:
30 May 2025, 13:55
RM: What loss?
Yet the haters will continue to hate
Just a fan's point of view*
Re: McLaren MCL39
Huge difference
sucof
39
Re: McLaren MCL39
SilviuAgo wrote:
30 May 2025, 13:55
RM: What loss?
Haha, why believe anything they say??
I think it is obvious every team member will always downplay any claims about their technology or changes. Especially in this case.
They will never say, what they changed, or how. That would be silly. This is a race.
venkyhere
45
Re: McLaren MCL39
CjC wrote:
30 May 2025, 14:36
SilviuAgo wrote:
30 May 2025, 13:55
RM: What loss?
Do you really believe what was said in that interview ? We can visually see a different carbon weave on the nose-wing junction.
sucof
39
Re: McLaren MCL39
Vanja #66 wrote:
30 May 2025, 14:42
Huge difference
https://pbs.twimg.com/media/GsMnuPiWEAA ... name=large
There is some, but I do not believe the real flexing shall be at the inside part of the wing...
The flexing will be the greatest at the end of the wing.
Also looking at the rig the FIA uses to measure flexing, I think this is a joke. Wings have very different forces on them at high wind speed, than what that rig is using. Hence the teams will just work on passing that test, while still able to let the wing flex under real racing conditions.
Why not just install FIA cameras with visual reference points, so that the flexing will be perfectly visible at any stage?
(by the way, I would support letting teams having any kind of flexi wing, instead of the active wing controls coming from next year..... Flexi wings actually do the same thing, and are simpler than doing an active version of them, while still working on to making them flex just the "right way")
Emag
Emag
137
Re: McLaren MCL39
Vanja #66 wrote:
30 May 2025, 14:42
Huge difference
So basically, they were already compliant with the TD?
I actually saw the MCL39’s front wing was flexing a lot less than MCL38 in testing, but the MCL38 flexed by a significant amount, so I thought maybe they were just going for it step-by-step with the MCL39 launch spec.
It seems the “new” clamp has changed nothing in the rigidity at high speeds.
Macklaren
Macklaren
Re: McLaren MCL39
Vanja #66 wrote:
30 May 2025, 14:42
Huge difference
excellent analysis.
but should we not look at the rate of change of each wing instead? do they both have the same starting points? what if angle of attack of each wing was set differently to begin with?
Re: McLaren MCL39
SilviuAgo wrote:
30 May 2025, 13:55
RM: What loss?
Based on the images they have made more changes than that. It's highlighted below.
(1) Different carbon weave directionality where the flap attaches to nosecone
(2) Additional flap strut
(3) modified angle adjuster bracket.
Beware of T-Rex
