The energy flow diagram in the technical regulations clearly show that the MGUK can only give or take 120kW from the ICE.Tommy Cookers wrote:most ? seem to believe that the braking-phase recovered power is limited to 120 kW
There seems to be some thought that the MGUH can be made to assist with engine braking.ringo wrote:Yes it is 120kW max. So the rest will be heat energy off the brakes.
Unless...
if the excess braking energy goes through the crank as engine braking and the MGUH is set to max load.
you can recover a bit there i guess. haven't looked at the details concerning that.
Would the rules allow rpm higher than 15,000 during engine braking? Just preventing ignition or fuel injection when 15,000 is exceeded would not stop using high revs to help spin the MGUH. Designing the engine to handle being just an air pump up to 18,000 or more might not be too hard.wuzak wrote:There seems to be some thought that the MGUH can be made to assist with engine braking.ringo wrote:Yes it is 120kW max. So the rest will be heat energy off the brakes.
Unless...
No, rev limit is strictly 15,000rpm.chip engineer wrote:Would the rules allow rpm higher than 15,000 during engine braking? Just preventing ignition or fuel injection when 15,000 is exceeded would not stop using high revs to help spin the MGUH. Designing the engine to handle being just an air pump up to 18,000 or more might not be too hard.wuzak wrote:There seems to be some thought that the MGUH can be made to assist with engine braking.ringo wrote:Yes it is 120kW max. So the rest will be heat energy off the brakes.
Unless...
Ah, so there's some sense in having a top-end rev limit.wuzak wrote:No, rev limit is strictly 15,000rpm.chip engineer wrote: Would the rules allow rpm higher than 15,000 during engine braking? Just preventing ignition or fuel injection when 15,000 is exceeded would not stop using high revs to help spin the MGUH. Designing the engine to handle being just an air pump up to 18,000 or more might not be too hard.
Im with you on this one. A few pages back i predicted that drivers would rev the engines close to the 15.000 RPM's during downshifts. Even though upshifts would happen at around 12.000 RPM's. Lets see what happens.timbo wrote:Ah, so there's some sense in having a top-end rev limit.wuzak wrote:No, rev limit is strictly 15,000rpm.chip engineer wrote: Would the rules allow rpm higher than 15,000 during engine braking? Just preventing ignition or fuel injection when 15,000 is exceeded would not stop using high revs to help spin the MGUH. Designing the engine to handle being just an air pump up to 18,000 or more might not be too hard.
Without it we would probably see drivers jump the gears to get ridiculously high revs at braking.
I get about 1MJ.ringo wrote:http://img716.imageshack.us/img716/1025/hdc.png
You may want to look on those as 120kW for all corners but put more focus on the energy and what amount of energy you can get from 120kW if the car brakes for x amount of time in corner x.
I was looking at the KE of the air since the engine is bacially an air pump. I figured the thermal energy would be negligible.WhiteBlue wrote:I bet it is negligible compared with 2-3 MW friction brake power. This is millions of Watt not thousands of Watt. The thermal power of the fuel at full flow is 1.3 MW. Of that you get 3.5 % or 45 kW to the MGU-H when the engine is at full power. Imagine what happens when you just compress the air without fuel. The air will never absorb any thing near the thermal power of the fuel. So perhaps you get 10% of the temperature. If the temp at the exhaust valves is 1100 C°and you generate 110°C by air braking you will get only 4.5 kW or 0.0045 MW brake power. That is 0.18% of the friction brake power.
Thing is, the graph of power vs time during a F1 braking is far from linear, the very high peak lasts very little time because the grip is strongly related to downforce hence speed.WhiteBlue wrote: Equally to Canada I made the assumption that average brake power is 50% of max Brembo brake power.
Nice find!!!f1motta wrote:Here is quite nice piece about new engines. A lot of knowledge gathered in a sinlge article.
Original [Polish] - http://www.f1talks.pl/2013/08/20/co-juz ... napedowych
Google translation [English] - http://bit.ly/19vbbok
