2020 Emilia Romagna Grand Prix - Imola, Oct 31 - Nov 01
SiLo
139
Re: 2020 Emilia Romagna Grand Prix - Imola, Oct 31 - Nov 01
Diesel wrote:
02 Nov 2020, 01:09
SiLo wrote:
01 Nov 2020, 23:41
Don't understand why they dont just tell lapped cars to drop to the back of the pack and then add a lap on, would be much safer
The timing system can't deal with that, it's been suggested several times in the past and that's always the reason they give.
So update it? It's 2020 not 1995
Felipe Baby!
dans79
267
SiLo wrote:
03 Nov 2020, 17:13
Diesel wrote:
02 Nov 2020, 01:09
SiLo wrote:
01 Nov 2020, 23:41
more like 1955!
202 105 104 9 9 7
NathanOlder
I think they should just drop back to the order they are in, if your a lap down, you are usually there for a reason. Why should they get their lap back?
GoLandoGo
Lewis v2.0
King George has arrived.
nzjrs
NathanOlder wrote:
03 Nov 2020, 18:42
I think FOM wants to minimize the number of "Mercedes laps half the field twice" type stories.
NathanOlder
nzjrs wrote:
03 Nov 2020, 18:51
NathanOlder wrote:
03 Nov 2020, 18:42
Yeah sounds about right. Its such a shame when we lose 2 or 3 laps for the annoying lapped cars getting their lap back.
GoLandoGo
Lewis v2.0
Big Tea
99
Why not have all lapped cars enter the pit lane as the 'parade' passes, then release them 20 seconds after the last car on the prime lap passes?
They will then have a delta to maintain position until restart.
Can be done with in 2 laps.
Big Tea wrote:
03 Nov 2020, 20:06
unfair advantage for the competition, the lapped cars will have colder tires.
that's what they'd say i'm sure of it.
indeed i think the best way is to have the lapped cars drop back, then qeue up.
a good programmer would fix any 'lap' issues without a problem.
I don't see the complicated issues either.
then again, what are we really talking about. 2 1/2 minutes, tops?
what's really the big fuss about?
notsofast
notsofast
Hypothetical situation. Gasly is the last car on the lead lap in P10, just ahead of Hamilton on the track before the safety car was deployed. Norris is in P11, having just been lapped by Hamilton. Now what?
Option 1. Give the lapped cars the equivalent of a blue flag and let them drop back. Now Gasly has lapped Norris, and Norris has no chance at a championship point.
Option 2. Let the lapped cars drop back, but make believe that they actually went all the way around the circuit. Norris is now behind Gasly on the lead lap and can fight for a championship point. This requires the timing system to adjust the lap count for the lapped cars. This could require major modifications to the timing system. And it also gives the lapped cars a potentially unfair advantage in the sense that their tyres will be up to one lap fresher. Gasly's tyres would go off one lap sooner, giving Norris a better chance at that final point.
Maybe I'm not thinking it through correctly, but it seems to me that the current approach is probably as fair as it is going to get.
Sieper
73
The only real problem when it comes to fairness is that the unlappers can warm up their tires really well whilst the waitees are getting even colder tires. Nowadays that is quite big. One Lap fresher tires seems less big?
e30ernest
e30ernest
27
I'd think they'll also say lapped cars will also end up with less mileage that way, which counts since they have to reuse engines/gearboxes.
notsofast wrote:
03 Nov 2020, 22:20
You are correct. The rule was done to add excitement. A lapped car can now fight again for a point.
NathanOlder
PlatinumZealot wrote:
04 Nov 2020, 02:14
notsofast wrote:
03 Nov 2020, 22:20
true, the only problem with it is, by doing so we lose 2 or even 3 laps of racing because of this routine. Therefore taking away more excitement than it gives. As an example, lets say at Imola, 7 laps to go, we have car stuck in the gravel. Out comes the SC. it takes the Marshalls 3 laps of SC speed to clear the car. Now lapped cars may unlap themselves. This takes a whole lap just for the cars to filter through as they are careful where they pass the other car. Then they give them another lap to get round and within reasonable distance to the pack or even back up to the pack. So we lost 5 laps in total now. So with 2 laps of the trace to go, it is restarted , no DRS now for the remainder of the race and unless you have a huge tyre advantage, the race is over at a track like Imola. Therefore the unlapping of car ruined all the excitement.
GoLandoGo
Lewis v2.0
basti313
basti313
NathanOlder wrote:
04 Nov 2020, 09:22
04 Nov 2020, 02:14
notsofast wrote:
03 Nov 2020, 22:20
Wait a second....you mean excitement is gone?
The unlapping was introduces as a "lex Vettel" for excitement: Some years ago a RedBull was build to secure a gap on the initial laps of the race to break DRS and drive the race home. This car was only really vulnerable on SC restarts. As lapped cars helped to keep a gap at the SC restart, the rule of the unlapping was introduced to get the strong drivers at this time like Alonso or Button into DRS range after the SC.
If you want excitement they need to cure the root cause, not such things as SC restarts...
Don`t russel the hamster!
SiLo
139
notsofast wrote:
03 Nov 2020, 22:20
Isnt this ignoring that Gasly would be at the back of the train here? The safety car would pick up Hamilton as the leader, if Gasly was in front he would be let go already and drive around to the back of the pack, then the lapped cars drop in behind and suddenly Norris is behind Gasly and on the same lap.
Felipe Baby!
Phil
66
Isn't this whole discussion about unlapping a bit moot? The goal of a GP is to do the mileage. If you don't unlap the cars and simply add some fancy math, they will not have done the mileage when they cross the line. I think part of the achievement of a GP is doing the entire mileage, not cutting them short by a lap.
#Team44 supporter
