Your inability to recognise the actual level of understanding demonstrated by that particular (AVL not Ilmor) "combustion engineer" clearly demonstrates your own level of understanding.Hoffman900 wrote: ↑17 May 2025, 16:30I’ve seen GG try to tell an Ilmor combustion engineer he was wrong about modern F1 PU’s by showing graphs from the early 90s elsewhere. They’re just stubborn.vorticism wrote: ↑16 May 2025, 20:18H900 seems to be speaking euphemistically while TC and gg are speaking more accurately. You can't detach piston speed from piston acceleration as H900 is holding to, but since the compression and tension forces experience by the piston & rod are described by f=ma then it's more accurate or at least more efficient to speak of a itself and not the separate components that a is derived from (stoke & speed). And as wuzak just posted, a being non-linear makes it the dominant component, beyond being a more useful derivative.
I reviewed the thread to which you refer after you posted a similar comment in this forum and had to shake my head at many instances of miscomprehension and confusion displayed by the "expert" you mention. (Do you still believe he has personal experience of an ICE with peak TE occuring at stoichiometry?) His multiple "appeals to authority" (along with your own) contrast with the actual evidence (eg graphs of any vintage) presented in that thread - i.e. ZERO!
