2026 Pre-Season Testing
CjC
CjC
Re: 2026 Pre-Season Testing
Oh my days. 3 days of ‘behind closed doors’ testing and 1 day of semi open to the public testing and we’ve already had the quote ‘best driver’ dropped in the forum.
:roll: :roll:
Just a fan's point of view*
FittingMechanics
FittingMechanics
CjC wrote:
11 Feb 2026, 22:33
:roll: :roll:
One Toto mindgame and Red Bull fans predict bigger domination than in 2023.
upsidedowntoast
upsidedowntoast
basti313 wrote:
11 Feb 2026, 22:31
upsidedowntoast wrote:
11 Feb 2026, 22:24
Honestly considering that Merc is still having trouble with hot weather and suspension 4-5 years on....
Or they went to the storrage and got their sandbags out again?
Sandbagging is meaningless here if Mclaren were at the top with the same engine.
chrisc90
11 Feb 2026, 23:05
basti313 wrote:
11 Feb 2026, 22:31
11 Feb 2026, 22:24
Any of these teams could have gone out and knocked in the fastest lap of the day.
Says nothing.
Need to dive deep into the panties, data, throttle traces to get a picture of order
carisi2k
29
These 26 cars look horrible in the slow speed corners and not much better in the medium ones either. In the medium turns I am noticing a lot of late turn in and avoidance of the apex.
FittingMechanics
FittingMechanics
11 Feb 2026, 23:05
basti313 wrote:
11 Feb 2026, 22:31
11 Feb 2026, 22:24
Mercedes PU engineer can probably mandate lower engine mode, especially if it is for the greater good (avoiding a penalty).
Don't write off Alpine.
#ReleasetheADUO
upsidedowntoast
upsidedowntoast
chrisc90 wrote:
11 Feb 2026, 23:08
11 Feb 2026, 23:05
basti313 wrote:
11 Feb 2026, 22:31
Says nothing.
True, but my point is that multiple Merc people (Toto, Shovlin, and George) have gone out and admitted that they were having problems with balance, setup, and the heat. Even if they are sandbagging, it looks like those problems are real, problems which Mclaren did not report they struggled with. And on the engine front Mclaren would have just as much incentive to sandbag as Mercedes.
SB15
SB15
FittingMechanics wrote:
11 Feb 2026, 22:46
CjC wrote:
11 Feb 2026, 22:33
:roll: :roll:
It's working :lol:
Emag wrote:
11 Feb 2026, 21:23
11 Feb 2026, 21:17
Emag wrote:
11 Feb 2026, 21:16
https://i.postimg.cc/hG89h7Yg/Analysis-V70a9i-Xq.jpg
The "long runs" from Lando, Charles and Max today.
Does the insights hub calculate gear ratios?
Not at the moment. I can try to estimate it but I am not sure if anything meaningful will pop out considering the low sample rate of the data.
Are the Speed and RPM data that bad? iirc, because there are so many data points, one might still be able to extract a gear ratio from a messy sample. I might do this manually. I thought it would be interesting to compare Mclaren's gear ratios to Mercedes with same PU, and then to compare Merc PU to the others to see the preferred RPM band.
My initial hunch skimming the data is that RB has slightly longer gears than Merc/Mclaren.
#ReleasetheADUO
Badger
Badger
46
12 Feb 2026, 01:14
Emag wrote:
11 Feb 2026, 21:23
11 Feb 2026, 21:17
When you have more deployment you need longer gears 8)
Zynerji
112
Isn't longer gears due to the electrical torque delivery?
TeamKoolGreen
TeamKoolGreen
Verstappen has been testing the following functions:
- Lowering the brightness level of the dashboard
- Turning off the radio before corners
- Activating dark mode on the screen
- Deactivating secondary button functions
- Drinking 2 litres before getting into the car to avoid using the hydratio
Seanspeed
Seanspeed
11 Feb 2026, 23:26
Are you saying this for any particular reason?
Seanspeed wrote:
12 Feb 2026, 02:51
11 Feb 2026, 23:26
Yes the team probably spent more time than anyone on their 2026 car. They had the highest windtunnel and CFD allocation. Rumor is they are very happy and are not chasing headline times. They have teething issues but it might be a very strong car when it is running.
#ReleasetheADUO
