Mclaren Mercedes MP4-25
Afterburner
Re: Vodafone Mclaren Mercedes MP4/25
Is it my impression or the radiator air intakes and sidepods are basically rectangular Brawn air intakes mixed with redbull compact sidepods?
The nose and it's double deck it's an Williams B version, my guess, and for what i see in pictures is that they invested aerodinamically most on the DDD and rear wing, that "hump" on the rear seems to channel more air into the rear wing...
f1rules
f1rules
634
this double splitter layout is really interesting
http://www.motorsport-total.com/f1/bild ... 1264765233
CMSMJ1
CMSMJ1
It looks like a pushrod to me too...
IMPERATOR REX ANGLORUM
bonjon1979
bonjon1979
30
Vasco wrote:are they using the same rear suspension layout as last years RBR?
Some better pics:
http://www.f1fanatic.co.uk/wp-content/u ... mp4_25.jpg
http://www.f1fanatic.co.uk/wp-content/u ... 4_25_2.jpg
http://www.f1fanatic.co.uk/wp-content/u ... 4_25_3.jpg
Diffuser is closed off
Definitely a push rod. Look at the second photo and you can see the suspension arm going diagonally up to the top of the crash structure.
djos
130
CMSMJ1 wrote:It looks like a pushrod to me too...
They are pushrods according to Maclaren themselves:
http://www.mclaren.com/f1season/2010/pr ... h-spec.php
VODAFONE McLAREN MERCEDES MP4-25 TECHNICAL SPECIFICATION
Chassis
Monocoque McLaren-moulded carbonfibre composite incorporating front and side impact structures
Front suspension Inboard torsion bar/damper system operated by pushrod and bell crank with a double wishbone arrangement
Rear suspension Inboard torsion bar/damper system operated by pushrod and bell crank with a double wishbone arrangement
Suspension dampers Koni
"In downforce we trust"
ESPImperium
ESPImperium
64
The things that have hit me from the MP4/25 are theese:
* Front splitter like what the FW32 had last year on its nose.
* Tightly waisted mid section, and tiny radiator inlets.
* Highly developed front wing, was tested last year but never raced.
* Gearbox radiator inlet splitter in the air box, very simmilar to what the Ferrari F2007 had.
* Red Bull RB5 style rear end, really small and tight. Must give DDD extra efficency.
* Red Bull RB5 style shark fin to aid yaw under braking and stabalise vibrations from the rear wing that potentially loose downforce from the flexing.
* Exausts seem to exit in such a way that they go thrugh the rear wing and try to destabalise the wake making the car harder to follow, as the following car will overheat more readily.
* More bulbous area where the fuel hose went on, but this is so the car can take onboard its full 150 or 160 kilos of fuel.
axle
axle
f1rules wrote:this double splitter layout is really interesting
Indeed - looks like they've worked on Williams' system last year and developed it further.
It's interesting that Williams "appears" to have dropped it...
- Axle
axle
axle
ESPImperium wrote:The things that have hit me from the MP4/25 are theese:
* FW31!
- Axle
Giblet
Giblet
Diesel wrote:
Giblet wrote:If you actually read the article that has been thoughtfully posted on the front page you will find it does indeed have pull rod this year.
Our eyes are only so good folks.
Funny looknig pull rod then, source of the article?
EDIT: I can't find anything in any article about a pull-rod, i'm calling BS?
Sorry my bad, I had a bunch of windows open, and was reading elswhere as well.
Push rod indeed.
Scania
Scania
is the bridge wing comback? :shock:
f1rules
f1rules
634
this design is just so refined, where the upper splitter ends, the lower frontsuspension wishbones acts as flow directors
Richard
Richard
I was wondering about that too .....
Diesel wrote:Look inside the airbox, two channels.
Dead zone located, I was suspecting all this time the inside of the bodywork could be used aerodynamically, however i did not want to spoil it for everybody. After the whole Goony thing from the start of the thread we all avoided the whole deadzone thing. Being a Mclaren fan too, i don't want other teams using Mclaren's innovations 8)
That opening under the air intake, may well be linked to the shark fin round back, Similar to the 2008 Ferrari nose.
Richard
Richard
Nice to see a tech spec, until you get to ....
Lubricants Mobil 1 – for higher performance, lower friction, better protection, cooling and wear resistance
... as if the other oils are for lower performance, higher friction, worse protection, cooling and wear resistance ??? #-o
Oh, and this made me giggle:
Radio - Kenwood
Wot no MP3? That'll not help pull the chicks as they do donuts in Macky-D's car park
ESPImperium
ESPImperium
64
Entering in the air box and exiting here???
Pics of the rear:
The air box splitte exits here???
