The Impact of Wake Turbulence on Downforce.
Re: The Impact of Wake Turbulence on Downforce.
F1 still uses ground effect! :roll:
toraabe
toraabe
Just_a_fan wrote:F1 still uses ground effect! :roll:
Not as the main downforce element. If you look at the Ferrari 126 c2 it doesn't even have a front wing http://yorozuya-f1and-etc.cocolog-nifty ... 4/vg55.jpg
All because of where the downforce is beinig created
The front wing is in ground effect. The floor is in ground effect. The rear wing isn't but then it wasn't back in the day either. A modern F1 car is a ground effect device it's just that the regulations limit how the designers achieve the result compared to thirty years ago.
riff_raff
riff_raff
Isn't one consideration with the design of the rear wing its effect on performance of the underbody?
I remember the very low and aft position of the rear wings used on IMSA GTP cars, which greatly improved the aero performance of the car's underwing.
A: Start with a large one!"
toraabe
toraabe
The lotus 125 with its massive underfloor tunnels creates 60% more downforce through its tunnels than the current flat floor in f1.
toraabe
toraabe
riff_raff wrote:Isn't one consideration with the design of the rear wing its effect on performance of the underbody?
http://vpstestbringatrailercom.c.pressc ... Rear_1.jpg
Because Imsa and group c were true ground effect cars. The venturi on these were massive and created massive downforce.
trinidefender
trinidefender
318
Have a source for this information? Not that I don't believe you I just like to see backed up numbers.
Pierce89
You got numbers?
OO7
OO7
171
toraabe wrote:Because Imsa and group c were true ground effect cars. The venturi on these were massive and created massive downforce.
tuj
tuj
does anyone know how AoA on the front wing could affect downforce in a trailing situation? Eg. could the lost downforce be recovered by running a steeper AoA during the trailing situation, reverting to an optimal AoA once the pass was complete?
They tried that in 2010, allowing the driver to increase front wing angle with the hopes of allowing a car to follow closer. Didn't work too well.
