2017 Belgian Grand Prix - Spa Francorchamps, 25-27 August
Shrieker
Re: 2017 Belgian Grand Prix - Spa Francorchamps, 25-27 August
godlameroso wrote:
05 Aug 2017, 20:50
I fully expect turn 9 to be flat as well.
NO way !
-Atatürk
Shrieker wrote:
08 Aug 2017, 02:20
godlameroso wrote:
05 Aug 2017, 20:50
NO way !
Isn't it already almost flat?
Shrieker
I would've thought that they used to lift completely. I don't recall any braking in recent years. But quite a big lift.
One other thing is that the racing line going into the corner had a bump that just loved unsettling the car. Is it gone with the repave ? Even so I think they'll be hard pressed to go full throttle thru that corner.
Edit: my bad. A touch of braking going into the corner in 2015, if the graphic is to be believed.
And the same in 2016 (again, if the graphic is to be believed.) I recall also from iracing that you had to brake a little before arriving the corner with the FW 31.
-Atatürk
It may be one of those ballsy corners where drivers can make up some time, or maybe sacrificing some speed through 7 & 8.
waynes
waynes
for the dutch fans making the trip (long i know) i hope Max's race lasts longer than the run to La Source
WaikeCU
Flat through 12 & 16?
garyjpaterson
WaikeCU wrote:
08 Aug 2017, 12:11
12, not sure. Maybe a downshift or just a lift.
16, yeah I think so.
Mandrake
Mandrake
waynes wrote:
08 Aug 2017, 08:25
Let's hope for the sake of keeping the championship interesting. The last thin I'd want to see is an overmotivated Verstappen bottling it again for him and others on Lap 1......
ThumbsUp
ThumbsUp
16
Mandrake wrote:
08 Aug 2017, 13:45
waynes wrote:
08 Aug 2017, 08:25
Please look at last years start and look closely to Vettel...
garyjpaterson wrote:
08 Aug 2017, 12:19
WaikeCU wrote:
08 Aug 2017, 12:11
I think it's possible to go flat through 12, but most likely no one has the skill or attachments to do it.
I do think the race lap record will be broken though.
Shrieker
08 Aug 2017, 12:19
Looking at the 2016 pole lap I would say yeah, it should be flat.
-Atatürk
Pouhon is gonna be amazing, Blanchimont however hasn't been a corner for years, easy flat.
And you guys calling those corners 12 and 16... shame on you.
16 is Paul Frere though isn't Blanchimont 17?
Looking at the map on page 1, 12 is Fagnes 1 (which sure as hell won't be close to flat) and 16 is the kink before Blanchimont, since both were mistaken i just aproximated to the closest thing.
Though i see now when you said 16 you meant Paul Frere/Stavelot 2.
Just use the names, it's an old track, the corners have names, Eau Rouge is cooler than "the 2-3-4 complex".
ChrisDanger
ChrisDanger
26
Sevach wrote:
09 Aug 2017, 05:40
Well, if we must use names...
Image(sic)
