Mercedes W12
JPower
JPower
43
Re: Mercedes W12
desl wrote:
02 Mar 2021, 13:01
https://i.imgur.com/OCRVBWU.png
Very interesting. If I had to guess, Mercedes spent tokens on the rear end. But what did they do?
Re: Mercedes W12
Mercedes uses tokens in the front to compensate for losing DAS.
Interesting how the boomerangs on the bargeboard are in line with the swept up wing that joins the side impact crash winglet by the sidepod undercut. They had the same feature last year.
You can also catch how high the leading edge of the floor has gotten.
Giando
93
Re: Mercedes W12
Is it just me? In the rendering pics it seems the sidepods bodywork is not the 'real' one.
In the photo with Bottas and the car on the background it seems the Petronas adhesive is way more vertical...
HungarianRacer
HungarianRacer
37
Re: Mercedes W12
godlameroso wrote:
02 Mar 2021, 15:11
Source?
Re: Mercedes W12
desl wrote:
02 Mar 2021, 13:01
Like RB, the hot air exits have been pulld inward and especially upward to clear the way towards the diffuser as much as possible.
The suspensions look similar to 2020... but the diffuser kick up point looks strange
mkay
mkay
16
Re: Mercedes W12
HungarianRacer wrote:
02 Mar 2021, 15:27
godlameroso wrote:
02 Mar 2021, 15:11
Source?
Pretty sure it was confirmed last year that Mercedes would NOT have to spent tokens to get rid of DAS. So if they did end up spending tokens at the front of the car, it's likely for something else.
OO7
OO7
171
Re: Mercedes W12
Blackout wrote:
02 Mar 2021, 15:46
desl wrote:
02 Mar 2021, 13:01
Mercedes already introduce a very similar design as part of an upgrade last year.
Starkblood80
Starkblood80
Re: Mercedes W12
Is it me or does has Mercedes managed to keep more floor area at the back compared to say, McLaren?
bauc
Re: Mercedes W12
Starkblood80 wrote:
02 Mar 2021, 16:17
Yes, at first glance that is the case, now the new packaging of the PU looks more central/vertical but please have in mind that Mclaren has a chassis made for Renault PU and small changes were allowed where the PU and the gearbox could not fit physically so its only natural that Mercedes will have the best packaged rear end of all.
Re: Mercedes W12
godlameroso wrote:
02 Mar 2021, 15:11
Why? They ran with both DAS and non-DAS racks last year so the non-DAS rack will just be carried over. No need to use tokens.
tmoneyr007
tmoneyr007
Re: Mercedes W12
I do not believe the nose in the rendering Vs the live pictures is the same. Actual nose is much slimmer in profile and the cape looks massive.
Jozsusz
Jozsusz
-3
Re: Mercedes W12
OO7 wrote:
02 Mar 2021, 14:18
Jozsusz wrote:
02 Mar 2021, 14:03
Blackout wrote:
02 Mar 2021, 14:02
So Mudflap was right (once again) see that bulge around the engine...
What did he say?
Mudflap being Mudflap :> viewtopic.php?p=932463#p932463
Thank you :)
Wow, incredible insights.
cplchanb
cplchanb
Re: Mercedes W12
It would be amazing if they actually brought neons for the underside for the night races just because theyre merc lol...
Not going to happen but it would a definite flex! :D
ChiiiZ
ChiiiZ
Re: Mercedes W12
I guess they might only shown us old chassis with new livery and some tiny change. The structure and suspension geometry seems unchanged, that means no token has been used. We might have to wait until the test to see the real W12.
Re: Mercedes W12
Just_a_fan wrote:
02 Mar 2021, 16:37
godlameroso wrote:
02 Mar 2021, 15:11
By removing DAS it allows one to reposition the steering rack and modify the monocoque for aero reasons.
