Alexf1 wrote: ↑09 May 2025, 11:18
FittingMechanics wrote: ↑09 May 2025, 10:23
Idea of PCM is not to use it for cooling of the brakes, it would be used to serve as a barrier between hot brakes and the wheels. Kind of like a insulator but that starts working at certain temperature, so you can gets some heat into the tire but not more than that.
Not sure if that would fall under "no liquid cooling", maybe, who knows.
A material inside the brake drum which at some point is liquid would
I guess a few thoughts B Sports though that a lining inside the drum cover so its unlikely I think to be cooling the brakes rather a barrier on heat escaping.
I wonder with AR3-GP mentioning something about the McLaren being draggier the DRS difference now being as high as other teams would this mean more air is required to released inside the drum - much like insulation maintaining a temp ins a house or what have you it could naturally build so more air required to move it out of the drums be causing drag?
A 2nd thought that could tie into this. Could it be a material that doesn't change phase to well above what ever temperates they are working with inside the covers? If the phase change occurs at say - and pull from the air only 300c but the drum lining only generally reaches 150-200c its extremely unlikely to ever reach a liquid state.
