HI, i have some suggestions regarding the new regulation boxes based on the official fia boxes that would not include any removal of aria except the old mirror stay.LVDH wrote: ↑25 Apr 2026, 19:55I have published a race schedule for 2026, rules and CAD files.
As I was so swamped in work, there is nothing very spectacular, for the first races, we will pretty much continue like we did last year.
I am working on a new version for MFlow, which should be a bit faster, more reliable post-processing and you should be able to use it on cloudHPC. I am looking forward to get this released in the next days.
There are also to small things to sort out before I can send out an invitation email. I hope that will be a matter of some two or three days.
You guys also requested a change in how we count championship points. I am open to this, so bang out some suggestions.
Hi everyone,LVDH wrote: ↑17 May 2026, 21:45Hi guys,
sorry for the very slow communication here. It seems the entire MVRC staff has very little spare time since a while. At least there is a new version of the CAD files and a new MFlow.
I tried to optimize the run times and memory usage, but it seems like we were already doing rather well. When using OF v2512 there is a new setting though. It is called early stop and is deactivated by default for now. You can turn it on, it will end the simulation when certain convergence criteria is met.
I hope this is no too big surprise (I think I mentioned it last year in the old thread) but for 2026, we will use OpenFOAM v2512! I hope this is OK for our Windows users. I think last year someone was able to write a short guide on how to run OF v2412 on Windows. So I hope, if there are questions, we can get the Windows people through this.
Also I like the ideas. I was never too sure about the cameras. I think on top of our cars it would not look very cool, but the ones ahead of the front suspension would be a factor for realism. So if someone can provide STEP files, I am open to add them to the mandatory parts.
Hi all, I have found following:AlexTitaneGP wrote: ↑18 May 2026, 15:02Hi everyone,LVDH wrote: ↑17 May 2026, 21:45Hi guys,
thank you for the update, could you describe rougly what are the CAD updates from the last CAD uploaded (V5.0 if I remember) ?
many thanks in advance
best regards
Alex
Hi,LVDH wrote: ↑17 May 2026, 21:45Hi guys,
Code: Select all
Selecting finite volume options type explicitPorositySource
Source: porosity_HX_2
Porosity region porosity_HX_2:
selecting model: DarcyForchheimer
creating porous zone: HX_2
[..]Code: Select all
--> FOAM Warning :
From virtual void Foam::functionObjects::forces::calcForcesMoments()
in file forces/forces.C at line 753
Porosity effects requested, but no porosity models found in the database
I think also some parts were renamed (mostly removing wrong "Mand_" prefixes).erdosg wrote: ↑18 May 2026, 16:32Hi all, I have found following:
-RV_Tail_V02 --> added design volume (broader on the sides of the volume)
-RV_Sidepods_EngCover_V02 --> added design volume (fin can be extended in +Z in almost entire length)
-MAND_Wheel_* wheels corrected, now all 4 is at correct position (but no geo change other than that)
Can anyone confirm, or did I miss something important?
Thanks for the info. Very helpful!
I cannot reproduce this. Can you please send me your case?erdosg wrote: ↑19 May 2026, 13:45Though, I have some issue using the newer MFlow releases (with WSL based OF). Specifically the porous media is not working. Everything works fine with deck generated in an older release (v2504a_win is the only I have), but it does not work with decks generated with new ones (v2605_win, v2509_win) from exact same input_files folder. I have tried to narrow down the differences (applying the changes one-by-one) -- I believe somehow the fUpdate with fvOptions and fvOptions_off is not working quite right, and when it is added, the porosity region is not generated.
In the solver log, the model generated by the old release has an additional message:not present in the log with the deck generated with newer release. The latter deck has a warning at each time step:Code: Select all
Selecting finite volume options type explicitPorositySource Source: porosity_HX_2 [...] Porosity region porosity_HX_2: selecting model: DarcyForchheimer creating porous zone: HX_2 [..]so likely the porosity region has not been defined - maybe do you guys have any hint, what could be the reason?Code: Select all
--> FOAM Warning : From virtual void Foam::functionObjects::forces::calcForcesMoments() in file forces/forces.C at line 753 Porosity effects requested, but no porosity models found in the database
I have the same problem on linux mint. Also I'm not getting the num_cfd_results.txt or any force numbers on the html file.erdosg wrote: ↑19 May 2026, 13:45The latter deck has a warning at each time step:Code: Select all
For the tail vomume you can add "Exhaust Winglet", similiar to the ones used by almost all the teams. But after adding them in the latest version of MntiumFlow (2605) I had positive exhauste pressure. On the version 2403a (the one I used before because that one was working on windows) I still have negative exhaust pressure. My question is if the possitve exhaust pressure results a penalty or DSQ or can be accepted without any consequences. Thanks.LVDH wrote: ↑22 May 2026, 11:23I think also some parts were renamed (mostly removing wrong "Mand_" prefixes).erdosg wrote: ↑18 May 2026, 16:32Hi all, I have found following:
Rules sayjanci_kp wrote: ↑25 May 2026, 15:36For the tail vomume you can add "Exhaust Winglet", similiar to the ones used by almost all the teams. But after adding them in the latest version of MntiumFlow (2605) I had positive exhauste pressure. On the version 2403a (the one I used before because that one was working on windows) I still have negative exhaust pressure. My question is if the possitve exhaust pressure results a penalty or DSQ or can be accepted without any consequences. Thanks.
so unless for the half car it is over 2.25 Pa.m2 (=2.25 N) we should be fine, or?Engine Exhaust
-Velocity boundary condition will be applied such that the total exhaust flow rate is 0.58 m3/s (whole car)
-Total surface integral of pressure must be <= 4.5 Pa.m2 (whole car)
I have registered once again now, just in case. Thank you!LVDH wrote: ↑01 Jun 2026, 17:11There was an issue with the team registration and every team has to go through the process once more. Right now, we are only at 8 registered teams. As I have written in the email about re-registering, somehow the registration form tells you about a confirmation email, but this only goes not to completely new, never registered users. I cannot change this message.
If you can clarify the 8 teams that seems to registered that would be helpful.LVDH wrote: ↑01 Jun 2026, 17:11
