taleed wrote:Question: An exceeded amount of oil leaks into the combustion area can lead to a loss of pressure that means less speed. Can this lead to an engine blow?
If it leaks that would mean that some mechanical failure happened on piston rings, head gasket or intake valve. Big loss of pressure/loss of oil in lubricating system would lead to overheating of rest of the oil because amount of oil circulating in engine would constantly drop leading to its overheating and therefore overheating of bearings finally leading to mechanical failures and possible blow (although overheated engine usually boils rather than blowing but it all depends on specific situation).
If all elements of engine would be overheated more-less in same amount than engine would stall and boil but if only one or just few parts would be overheated than such imballance would lead to blow rather than stalling.
Example: If all bearings on crankshaft would be overheated in same amount engine would probably stall but if only one or few more bearings would be overheated than eventually that would lead of snapping of one connecting rod which would than make the hole in block (blow) or launch the piston so that it would smash the valves and head (blow).
Basically there are two kinds of blows - blow trough exhaust or blow trough the hole in engine block although they can happen in the same time.
