2010 - 4WD legalized for budget capped teams. Effects?
Will 4WD be used in 2010?
Poll ended at 30 May 2009, 22:11
No
25%
It'll be tried and quickly removed/banned
2%
Yes, it will make the car slower
2%
Yes, but it won't make much difference
2%
Yes, it will be slightly faster
9%
Yes, it'll be much faster but only in the wet
11%
Yes, and it will dominate in the wet and dry
14%
He's not the messiah, he's a very naughty boy!
34%
Total votes: 44
Scania
Scania
Re: 2010 - 4WD legalized for budget capped teams. Effects?
if we transfer the engine power by shaft or hydraulic, it will make extra weight & use more space, & need more final drive cooling system.
is this possible for this?
the KERS has 120kW=30kw/wheel, normal, we will use a 30kw hub motor on front wheel.
if combine front wheel driver & front KERS together, & we want to transfer 160kW power to front axle, that means 80kW per each front wheel.
in my idea, I will use a 190kW hub motor on each front wheel, and a 160kW generator connected to engine.
while don't use kers, the generator drive the front axle directly, it will provide 80kW to each wheel.
while braking, the rear KERS motor, generator & hub motor will charge kers store device together. it won't thouch the rule because no KERS input limite in new rule.
while use KERS, the battery will provide power to 60kW rear motor and provide 30kW to each front hub motor, the generator will still provide 80kW to each front motor.
rough drawing
