Actually if it doesn't work as well as they intended it to, I think they'll revert back to the launch position and probably be fine. It seemed to work well. It's nice to have options.Adrian Newby wrote:If their EBD doesn't work well enough, Red Bull are more fully invested in it than the other teams and will pay a larger price for their mis-step.
mozza_84 wrote: you do know that the dosnt shine out of adrian neweys you know what he has copied and twisted mclarens and saubers idea simple as.
The flow doesn't follow both of those paths at the same time. The default is to go to the floor/diffuser. Only at the highest speeds will it get blown back down the ramp.hardingfv32 wrote:Crucial_Xtreme wrote:What makes you think RB has compromised the airflow around the rear of the sidepods?
Is this not a compromise, the flow splitting and going to two different locations.
Brian
Do you think? Let me ask you a question. Which flow is greater(in terms of amount of flow) and which flow is stronger, the flow over the sidepods or the flow around the sidepods?Adrian Newby wrote:
Really, how do you know? Without actually asking the designer and seeing the testing results how can anyone be sure?Adrian Newby wrote:The flow doesn't follow both of those paths at the same time. The default is to go to the floor/diffuser. Only at the highest speeds will it get blown back down the ramp.
It's all just conjecture, isn't it? We are just taking our best shots at what makes the most sense to each of us. This makes the most sense to me (that, and I hacked into n smikle's super-private CFD results).horse wrote:Really, how do you know? Without actually asking the designer and seeing the testing results how can anyone be sure?Adrian Newby wrote:The flow doesn't follow both of those paths at the same time. The default is to go to the floor/diffuser. Only at the highest speeds will it get blown back down the ramp.
I think the canal after the exhaust exit is misleading. All it can do is impart some twist, perhaps.
Where it goes after that, I'll be damned if anyone can persuade me with photoshop.
how on earth do you plan to collect anything in an open free stream environment. redirect sure but no way you will collect anything.MIKEY_! wrote:Can anyone tell me what the regulations ban collection and redirection? I have looked already and found nothing.
