flyboy2160 wrote:ben's guide to vd makes no sense.
I do not possess a degree in engineering nor am I mechanically inclined...
F1Technical wrote:No sh|t.
...but this stuff is ain't exactly rocket surgery.
Air is drawn in from the dual intakes. It then fills the duct, increasing static air pressure within the duct. Taking the path of least resistance, as things in nature tend to do, air pressure is relieved through the larger of the two exits, Exit 1, when the duct reaches capacity. (Programme note: I've flipped the numbers of my original diagram to reflect their use chronologically.)
As the car continues to accelerate and draws in yet more air, the pressure builds to a point where the duct and Exit 1 can no longer handle all the pressure. Rather than cause the duct to explode, the pressure then follows the next path of least resistance, which is Exit 2. That exit is conveniently located under the main plane, and the pressure release at that exit then stalls the trailing edge of the main plane by deflecting the laminar flow that ordinarily flows over the trailing edge of the main plane. Hence, drag reduction.
Incredulity wrote:Why not just make it all even easier and have only one exit?
Good question. The system has to be able to function with the car at top speed. Top speed means tons of air pressure. Without the ability to bleed excess pressure, the system would become completely pressurized well before the car reaches top speed. If the system is completely pressurized, it can't work, because the inlet is then, by definition, choked.
Incredulity wrote:Why does it have its own diffuser?
Another good question. In order for the duct to accumulate the initial pressure required to set off the chain of events I've described, Exit 1 must be relatively small. In other words, it must release less air than the system draws in so that the duct doesn't immediately bleed pressure as it's accumulated. The problem with a small initial exit is that as the duct handles increasingly higher pressure, the exit isn't large enough to bleed sufficient pressure to prevent the system from becoming completely pressurized. The diffuser creates an area of localized low pressure behind the vent that helps to extract more pressure from the duct when the car is at or near top speed. Higher airspeed around the diffuser proportionally increases its efficiency.
Incredulity wrote:You're the man! Is there anything else we should know?
Thanks. Anything else? Hmm. Only that this could also be a great way to use air that's drawn into the side pods after it's passed through the radiators to cool the engine. That would definitely add to the system's complexity. But, it could be worthwhile nonetheless.
Incredulity wrote:Wait. Did you really use a picture of chlamydia in your diagram? What's wrong with you?
Yes, and I really don't know. But, don't ever, ever,
ever do an image search for chlamydia.
EVER!
The only difficulty with this system - aside from explaining it - is that much like real VD, this VD can be a pain in the ass. Everything I've described must happen very
quickly, very
orderly and, most importantly, it must happen
consistently. It also has to have the
flexibility to react to changing vehicle airspeeds. If any of these aspects are out of whack, this system can easily sabotage performance, i.e. it can blow when it shouldn't or not blow when it should. But, such problems can be remedied by varying the size of the various inlets and exits until the system is harmonious with the car and the circuit upon which the car is being driven.
I think the potential for VD is profound (you can use it on the front wing, too). It just might take a while to get right.
EDIT: Please be kind and attribute to me any pictures I've created (which are all edited or drawn pictures in my posts) if they are to be used elsewhere. I've got an ego to tend to, yanno?
EDIT: Someone stop me from editing this!
